Baghira Balance Weight Gear
Postby Zedthou » Mon Jan 21, 2019 1:52 pm
balance weight gear info required please,i'm aware that a 700 Raptor solid gear is the most common one used to replace the Baghira/XT sprung gear,can anybody supply a part number &/or the Raptor year/model for the recommended gear to use?.
Also,are there any other gears that are a direct swap?,will a slotted gear off a 91-98 XT660 Tenere,part number 5Y1-11531-00 fit?
Cheers..........
Zedthou
Re: Baghira Balance Weight Gear
Postby droy » Tue Jan 22, 2019 1:03 pm
[b]Gang of Four
1997 Replica
1996 Tour (Track Day Project)
Montclair, NJ USA
droy
Postby Zedthou » Tue Jan 22, 2019 4:17 pm
Thanks,i've seen that video a few times but i don't recall him stating any exact details regarding the gear needed unless i missed it?
Zedthou
Postby droy » Wed Jan 23, 2019 6:53 am
Gear, Drive (model year 2007 works)
1S3-11536-00-00
Yamaha
Got mine from fleabay
Like this -
https://www.ebay.com/itm/2007-07-YAMAHA ... rk:10:pf:0
its the gear on the upper right that you need.
[b]Gang of Four
1997 Replica
Montclair, NJ USA
droy
Postby Zedthou » Thu Jan 24, 2019 8:16 am
Thanks man,much appreciated!
Zedthou
Postby droy » Thu Jan 24, 2019 11:11 am
btw - the raptor shear key is to long to use unless you cut it down in length
[b]Gang of Four
1997 Replica
Montclair, NJ USA
droy
Postby Zedthou » Thu Jan 24, 2019 2:49 pm
I'm assuming you can use the OEM Baghira/XT key?
Zedthou
Postby droy » Fri Jan 25, 2019 10:43 pm
yes as long as it in good shape.
[b]Gang of Four
1997 Replica
Montclair, NJ USA
droy
