by albert1917 » Sun Feb 02, 2020 9:46 am
just bought a 1980 ts 125 frame with engine fitted, the wiring has been chopped so the headlight and ing switch could be removed in the past, what would be the easiest way to hot wire so I can start and check the engine? it only needs to be run a couple of minuets so charging isnt an issue.
albert1917
by Puffs » Mon Feb 03, 2020 5:28 am
Hi Albert - a battery feeding the ignition coil via the contact breakers should do the trick.
- Moderator
