Blathian wrote:could that leak have happend when he did the oil change??
Blathian wrote:because all he did he said was oil change and adjusted my carborator. he says returning the idle to where it was makes it backfire more..says i should have rejeted for the m4 pipe, but i was told it wasnt needed as its a bolt on pipe.
phlat65 wrote:why not do your own oil change? the parts are $25-40 depending on oil you use, and the proceedure is very simple.
Blathian wrote:thanks for the information, yeah it definetly backifires more now, and idles much faster, its always had a low grumble before now its definetly different...what about valve adjustment?? he said its good to do one at this stage of the motor,5000km, and that a tight valve could cause the excesive backfiring.
