Norman Wade wrote:According to the parts book, MZ changed the type of Paioli fork used after 1996. From the parts book:
"OLD FORK VERSION: slider dark grey without any signs on the lower surface of the slider.
NEW FORK SLIDER: SLIDER SILVER COLOURED or dark grey with a cross sign and / or a poit sign on the lower surface of the slider"
Also found this piece of information somewhere:
Fork Oil Changing.
To drain, remove front wheel, locate drain plug in each leg slider, remove and drain oil. To check level of oil, remove both upper fork plugs. Remove both spacer tubes and then the springs. Position the sliders fully up. Measure from the top rim of stanchion to oil level.
Type: Early grey sliders
Oil Level : 220mm
Amount: 340ml
Grade: SAE 30
Type: Later silver sliders
Oil Level: 220ml
Amount: 300ml
Grade: SAE 10
Norman
http://www.mzskorpion.net
Users browsing this forum: No registered users and 0 guests
