Oil change Yamaha parts numbers
Postby kman.45 » Sun Nov 19, 2006 12:46 pm
This has probaby been posted previously, but...
A couple of Yamaha (US?) part numbers for oil change stuff. The drain plug crush gasket is 214-11198-01 and an o-ring that will work for the oil pipe is 93210-10096-00. The drain plug gasket was $0.99 and the o-ring was $1.50. I think by the MZ spec the o-ring is 11mm inner diameter and 2mm thick. The Yamaha part might be a tad less in diameter but it fits and works well.
BTW, if you are silly enough to not get one of those oil pipe bolts back in correctly, the Heli-Coil M6x1 kit at your friendly auto parts dealer is $30. You should hope your lucky enough to have the upper one strip as at least you can get to that one straight on. I won't be removing the bolts all the way to do an oil change anymore...argh.
kman
kman.45
oil filter
Postby DAVID THOMPSON » Sun Nov 19, 2006 2:13 pm
kn 145 the filter the 660 motors
Manufacturer Part Number
YAMAHA 4X7134409000
YAMAHA 583134401000
YAMAHA 5JX134400000
YAMAHA 2H0134409000
YAMAHA 4X7134400000
YAMAHA 4X7134400100
http://www.knfilters.com/search/kn_cros ... ?kn=KN-145
http://www.knfilters.com/search/product ... rod=KN-145
Servicing - Timing Plug
Postby sapperk9 » Mon Dec 04, 2006 3:21 pm
Check:
http://www.corsemeccanica.com/MZ%20timing%20plug.jpg
VAST improvement, also just look at the total Ti parts at Corse Meccanica:
http://www.corsemeccanica.com/mz_skorpion.htm
Nice stuff, I used it when I replaced the Bilsten rear shock with a Penske.
"In questions of science the authority of a thousand is not worth the humble reasoning of a single individual." - Galileo Galilei
sapperk9
Re: Servicing - Timing Plug
Postby roge-a-billy » Tue Dec 05, 2006 3:21 am
sapperk9 wrote:Check:
At 2$ to a £ a set of FCR's could be £500 (approx) then you have import tax etc :roll:
roge-a-billy
