Skorpion Brake Rotor Again
Postby Jimbo » Mon Jan 15, 2007 12:14 pm
If no one knows the answer to my last post, how about any after market brake rotor for the Sport Cup? I know EBC makes a Pro Light rotor, which I have tried to order from Bike Bandit twice this past year, only to be told its back ordered. I actually think this rotor for the Skorpion doesn't exist in this world. Thanks. Jimbo
Jimbo
Postby DEmark » Mon Jan 15, 2007 12:29 pm
You can get ANYTHING for your MZ in 5 to 14 days from Phil at BSA Regal call 011 44 23 8036 6404 remember there is a 6 hr time difference.
DEmark
Postby ZzerO » Mon Jan 15, 2007 12:57 pm
hi jimbo there are several brake rotors that fit the skorpion, some of the ducati rotors fit, and also from the yamaha tzr 125 and szr. i'm sure there are even more bikes where the brake rotor is the same
ZzerO
ROTOR
Postby omrra91 » Wed Jan 17, 2007 12:20 am
Jimbo,
I just baught a brand new front brake rotor for my Skorpion race bike. Now I don't need it because I bought the TZR660 Steve helped to post on the board last month. I'd love to ship it to rather than have it sit around. You would also be helping out a racer on a tight budget. The part cost me $99.00. A sponsor covered the shipping so that's all I have into it. I would appeciate a resonable offer. Otherwise I can try the for sale forum.
Regards, Jeffrey Thompson
omrra91
Postby hb7 » Wed Jan 17, 2007 1:14 am
Which Ducati rotor is 316mm....?
I can't find it in the EBC cross directory.
There is no other application in EBC catalog for the
Skorp rotor.
Omrra is that a stock OE rotor of an after market rotor?
hb7
Skorpion rotor again
Postby Jimbo » Wed Jan 17, 2007 9:45 am
I just ordered a new Grimeca rotor from Phil at BSA Regal. Thanks for all the input from everyone. Jimbo
Jimbo
Postby dbates » Wed Jan 17, 2007 12:32 pm
I had orderd a rotor for my skorp (traveller MD619RS))via brakes4u.co.uk and it arrived in about 3 days. I would check that the place you tried first actually ordered it.
I didin't get the oem from phil as I had gone through 3 of them in the past year and they kept warping no one could find any mis alignment problems or frozen pistons so I thought I would try something else.
dbates
2001 Skorpion Traveller
Northumberland England
dbates
Postby hb7 » Wed Jan 17, 2007 1:34 pm
Warping.....how did you measure the runout ?
Are you hard on the brakes ....stoppies etc? ?
The pistons have a tendency to stick....unless lubricated with silicone grease.
MD619RS is the EBC rotor with an alu
center carrier.
hb7
Postby Jimbo » Wed Jan 17, 2007 4:31 pm
Thanks for the input. I just ordered the EBC rotor that I wanted originally from the brakes4u website. Thank you. Now I'll have to cancel the brake rotor order I placed this morning from BSA Regal (I really didn't want the stock rotor anyhow, but was having trouble finding the EBC rotor.) This is a great forum. Thanks for all the help. Jimbo
Jimbo
Postby dbates » Thu Jan 18, 2007 1:25 pm
First two times it warped a main dealer checked it and yep its warped they replaced it both times under warranty no hassles no problem. By the third time I didn't need anyone to tell me, and I thought I'll try something different so replaced the caliper rotor and pads at the same time.
No stoppies not what I would consider hard on the brakes could have been a bad batch of discs or my bad luck.
Now I throughly clean the brake on a regular basis and keep it thoughly lubricated with brake fulid on any reassembly and are very careful about positioning when I reattach the caliper.
Looking for wood to knock on now.
I would say the EBC one seems to be a significant quality step up from the oem one. so far....
dbates
dbates
Postby hb7 » Thu Jan 18, 2007 2:38 pm
Actually, the EBC with it's Alu semi floating carrier will get sloppy before the stock rotor. The stock uses steel on steel contruction. I'm not convinced about steel on alu for longevity.
They went to Alu to save a few ounces...for the racing posers.
hb7
bent
Postby DAVID THOMPSON » Thu Jan 18, 2007 9:04 pm
bent and wharped rotors seem to be common on these bikes
my rt125 had one and the saxon tour had one that was replaced
by the first owner
all is well with both now
ar dave
