by Bill Jurgenson » Tue Mar 20, 2007 1:22 am
no serious fitment issues, can be bolted thru the original hole but need a bit of adaptation.
Rear sets are my own in both cases.
The older ones, seen on the red machine are now on Chris Hunsicker's racer.
I sold the red machine later and that a--h--- had nothing better to do than to dimantle it for parts after feigning to eally want a sporty modified Skorpion for his own use. You will notice, that the bike also has Brembo wheels and brakes and shortly after the photo got the custom exhaust mounted on the other bike. It also had Tomasselli forged clipons and Mikuni TM34-65 Carbs and a Wilbers strut.
I would have sold ithad I known what a jerk he is...
the other brackets are the same as on my racer. We milled two sets and have welded both set since after spills. The brake lever on the Tour is Yamaha OEM SZR/TZR, the pegs MuZ OEM Replica; the lever fits the peg perfectly. There is no shift linkage; I use a vintage MZ TS150 lever
reversed on both Skorpions and the SZR.
I ride first gear up whereever possible and I recommend to each and all change. It is much more natural and , on the track, often the only way possible.
The racer uses "Metisse" pegs and brake lever.
Off topic, but before anyone asks, thru the hole in the fairing you can see the pickup for the SilentHektik battery ignition on the end of the crankshaft. There is no flywheel.
- Attachments
- shows TS 150 lever reversed and also Mecdine quickshifter
- 2007_left.jpg (72.29 KiB) Viewed 2907 times
- shows CNC bracket with MZ peg and Yamaha lever
- Peg.jpg (87.07 KiB) Viewed 2907 times
