Wanted: swingarm rubber protector.
Postby skyguy » Tue Jun 05, 2007 12:41 pm
Hi all, I need the rubber swing arm protector that stops the chain from slapping the swing arm.
It came unglued and got sucked up behind the front sprocket. Destroyed the output shaft seal.........................
Another item that I am having some difficulty finding is the output shaft seal. Does anyone have a good source for metric seals? Seems this one is an odd size.
Skyguy
1998 MZ Traveler
skyguy
swingarm protector
Postby Bill Jurgenson » Wed Jun 06, 2007 12:49 am
HI,
I can send you one. They are easily had directly from th factory. I have my own stock or 4-5 on the shelf.
I will look if I have the seal but can get it over the counter in town.
B
Postby hb7 » Wed Jun 06, 2007 12:12 pm
Seal is Yamaha 93102-12321-00 $3.40
OIL SEAL,SD-TYPE
Rubber chain guard is ~$12 from bikeworx...
hb7
Re: Wanted: swingarm rubber protector.
Postby Dullthud » Fri Dec 14, 2007 10:49 am
Skyguy.
I needed a swingarm rubber while there was no UK parts supplier recently. I made one out of a bicycle inner tube and it's still working fine. 1000 miles. I must get a proper one at some point for the sake of tidiness.
Thanks for reminding me.
Dt
Dullthud
Postby MSW » Sun Dec 16, 2007 2:00 am
The output shaft seal is Yamaha part no. 93102-25218-00. You can have your local Yamaha dealer order it (ouch!), or you could order it from an online vendor, like Mr. Cycles, which, BTW, has a great site with the fiche for the 1995 XT600 here:
http://www.mrcycles.com/fiche_section_detail.asp?category=Motorcycles&make=Yamaha&year=1995&fveh=661
BTW, we are talking about a Baggie here, right?
MSW
2005 Black Panther
MSW
Users browsing this forum: Bing [Bot] and 1 guest
