Engine trouble 660
Engine trouble 660
Postby Fredrik » Fri Sep 29, 2006 4:02 pm
My first try in this forum! I have a Mastiff 660, 1998 model with engine trouble. Was on a trip yesterday and had been driving for 4-5 hours, and stopped for 1/2-hour. When going off again the battery was flat. Just before I stopped a recognized that the RPM indicator just worked between 0-1800 rpm. When over 1800 it dropped dead to 0 but the engine was still running perfect. OK, flat battery. Managed to start it by pushing, running good. Hit the road and after one minute it just did work extremly bad over 1800 rpm. Idle at 1400 rpm = perfect. Checked the battery = bad things, 5Volt. Put in a new battery, checked charging, 14 volts = OK? Still running bad over 1800 rpm but sometimes it's possible to cheat it and get it work fine for 5-10 seconds. A friend stated that the CDI-box have three ranges : low, medium and high and it can work fine in low and high range. True ?
Could the low voltage on the battery result in a too high charging voltage that have damaged the CDI-box the way my friend stated? Maybe something else is damaged ?
I would really appriciate help on this!
Fredrik
Postby phlat65 » Fri Sep 29, 2006 8:51 pm
yes the cdi could have been damaged. most common problem we have seen is corrosion in connectors, esp ones that carry current like charging system. if you have a DVOM, check for excessive AC voltage at the battery.
I would disconnect every connector you can get to, and clean and apply some waterproofer, or contact grease. removal of the fuel tank will make it much easier.
good luck!!
Postby Wonky » Mon Oct 02, 2006 3:56 am
Yes the CDI box can be damaged if run with a faulty battery! Also as just suggested above, use contact cleaner on your terminals if they look dark in colour, or rusty. You may have a problem in your wiring loom thats causing your problem, do you have a friend with a Mastiff/Baghira? Try using their CDI box and see if that cures it, if not then check relays,etc on loom. Or talk to David T, hes a bit of a wizz with the old electrics!!!!
Wonky
diode
Postby DAVID THOMPSON » Mon Oct 02, 2006 11:35 am
there are diodes in the wire looms of the mz bikes that i have not seen in other makes these are to control spikes in the voltage from relays and the spark coil they can cause funny readings if you do not know there there
when checking with a voltmeter
several riders have said they have found some blown out.. one is under the gastank in the loom if blown or shorted they can cause funny things to happen :(
electrical drawing are avabile i can forward them if needed
these bikes are bad about corrison in the connector plugs
and DO keep a close inspection of the battery condition as it is the sorce
of many problems due to its small size
Postby Wonky » Mon Oct 02, 2006 1:18 pm
Wonky
Postby Chris Hunsicker » Thu Oct 12, 2006 1:57 pm
This from a previous post:
I wanted to repost the link to a terrific Skorpion resource--a wiring diagram from Tony Idle of the UK who originally posted it on the Yahoo group MZOG.
If you find Yahoo as much of a pain as I do, you can find Tony's diagram on
http://www.mzskorpion.de
Click on "racing/tuning," and then the 3rd item down is the one to click on: "Schaltpläne als ZIP (0,8 MB)"
Also, if the Baggy is like the Skorpion, a faulty tachometer can make the bike run poorly. Unplug the tach, and see if the problem goes away. I *think* the CDI boxes only rarely fail.
Chris Hunsicker, Philadelphia
Chris Hunsicker
Postby Nils D » Mon Aug 06, 2007 4:13 pm
Chris Hunsicker wrote:This from a previous post:
Chris, could you (or somebody else) tell more about what a faulty tachometer could cause.
My tachometer behaves normal at low speed and low revs. And it is quiet steady at 110 km/h, even if it then says the engine is running at 4500 revs, seams to low. But if I then slow down to 90 km/h, the needle bounces between 2500 and 6000 revs.
Recently my battery has started to dry very quickly, as if it is being charged to much. I have to ad more destilled water every 400 km.
What could cause this? A faulty tachometer? Or what?
Best regards,
Nils
Skorpion Traveller 96
Nils D
relay 19
Postby DAVID THOMPSON » Tue Aug 07, 2007 12:37 am
relay 19 (cutout relay) part of side stand interlock wireing and supplys cdi box with power....
look close at this relay it is to small and it failed the other day on my rt125
i have been having funny tach readings most of the summer....
from time to time bike would not start with kick stand down..
then last Thursday it just died
i jumped pin 3 to pin 5 and rode it home
replaced relay and no trouble for 6 days now
ar dave
ps on my rt125 it is mounted beside the battery and it is gray in color
the contacts carry a lot of current and supply's the cdi box on my rt125
so funny tach reading from funny voltage supply to cdi box ????
cdi box drives tach on most bikes
SEE ALSO HERE FOR REPLACEMENT RELAY DRAWING
http://www.mzriders.com/mz/viewtopic.php?p=12180#12180
Postby Chris Hunsicker » Tue Aug 14, 2007 10:31 am
Best regards,
Nils
Nils, I'm afraid I can't give you a definitive answer.
Somehow a faulty tach can cause the engine to missfire. Does your engine perform poorly when your tach starts to be erratic? If so, just unplug the connector at the back of the tach, and see if you still notice the problem.
You may have a faulty tach or have a separate issue that is causing your engine to misbehave.
These tachs are notoriously bad. There has been a lot of discussion on the MZSkporpion.de board about them in years past. Some people replace the whole instrument cluster with something aftermarket, but apparently one can still get the tach from MZ.
That said, I'm not so sure the tachs are terribly accurate, even when they are working correctly.
Hope this helps and good luck.
-Chris, Philadelphiariders.com
Chris Hunsicker
Postby Bill Jurgenson » Wed Aug 15, 2007 12:44 am
Yes the MBB tachs are worse than bad and even even working after a fashion, the values shown are from a different planet. Rest assured that the Denso CDI cuts the engine at precisely 7200rpm, regardless of what you see - or don't as the case may be.
As far as ill effects are concerned, it is really quite simple; the tach gets its signal directly from the coil, so if the circuitboard of the tach goes bad it can short out the ignition circuit and bingo - misfiring or totally dead.
Postby Chris Hunsicker » Thu Aug 16, 2007 8:06 am
For the record, here's the MFG's web site:
http://www.nova-mmb.com/
Chris Hunsicker
Postby Nils D » Fri Aug 17, 2007 10:46 am
Hmmm....
The tachometer has been strange for over a year. (It started with a electric black-out. It turned out to be the horn that had shortcuted. Just to get home, I got help to jumper. But during that 200km journey, the tachometer was far over the scale, just going down a bit if i used the indicators. Since then there has always been something strange with my traveller.)
The engine runs OK, apart from some missfireing at low speed. It has become worse this summer. I can sometimes provoke short, but total, loss of current by fidling around with the ignition-lock or its loom. I have opend and cleaned the ignition-switch, but the problem remains.
I realize this will cost. Time and money.
I have started to work me throug the conectors.
I have bought a new battery. (Had to be done soner or later.)
The tachometer is so expensive I might just unplugg it.
Since the ignition-lock is bad I have ordered a lock-kit wich also contains a fresch switch.
The screws holding the ignition-lock, do you think they can be drilled out? Or are they made of hardend steel?
Still serching, Nils
Nils D
Postby hb7 » Fri Aug 17, 2007 10:47 pm
They are one way hardened screws...and yes they can be drilled if you use very high quality drills, then tap in your easy out.
You have to remove the top triple to do it. The switch at the bottom is replaceable without having to change the lock.
ps: I used a drill press and recommend you do too.
The tach is repairable...open it up and resoldering the board worked for me.
hb7
Postby Nils D » Mon Sep 24, 2007 6:01 pm
hb7 wrote:The tach is repairable...open it up and resoldering the board worked for me.
Thank you for giving me the curage to "break" open the tachometer. I had no idea what I could meet inside, but it was quiet obvious what had to be resoldered. (Yes, you can't take on and of the glass of the tachometer more than just a few times.) I can't tell how accurate my tachometer is, but it doesn't suffer from hysteria any longer.
For the moment I think everything om my Skorpion Traveller works perfectly. (Touch wood!)
And a word of wisdom from an amateure like me: If you have electrical problems, that doesn't blew the fuses, look at the conectors right after the battery.
Nils
Nils D
Postby hb7 » Tue Sep 25, 2007 1:05 am
Good to hear it worked for you. Once the the tach bezel is gone....You can seal with silicone and tape it up.....or use a hose clamp to hold the glass/o ring in place.
hb7
Users browsing this forum: No registered users and 0 guests
