by Bill Jurgenson » Fri Sep 07, 2007 1:10 am
I, too, have only the lower bracket, similar to what Chris has but from steel tubing, actually just the original part trimmed to a minimum. Never had the vertical part up the mirror, only the cage tube from the front to support the mirror even when the bike as street going.
Why don't you just weld it back together, it is all of mild steel in the OEM version?
If you are using the original mirrors, you probably need the support. I have mirrors from the Cagiva Mito.
Having decided not to race any more, the racer will look a bit like that again, with full fairing and a different better exhaust taken from my blue bike which as been retired for parts. I want to register it again for the road.
- Attachments
- the street-legal "racer" originally looked like this:
- RWE 1.jpg (63.01 KiB) Viewed 2606 times
- you can just see the mountings here.
- cage.jpg (143.11 KiB) Viewed 2606 times
