snapped oil plug
snapped oil plug
Postby handsomejackuk » Fri Oct 05, 2007 1:57 pm
Anyone know where i can get a new oil bolt for frame bottom ? It is a banjo bolt with a strainer fitted on top. I removed it tonight to change oil, drained all oil and put it back in and snapped it. Think I tightened it to hard. It is the one that fits on bottom of frame that has a braided hose on it. Would it be o.k. to put a standard banjo bolt in there with no stariner.
Alun
handsomejackuk
Postby keithcross » Fri Oct 05, 2007 2:23 pm
Having covered over 50,000 miles on my Baggi, I have never foound any crud on the strainer you are talking about.
Sayin that, with my luck if I run without it, an unseen peice of weld would fall into the oil tank and wreck my engine :)
oil strainer
Postby handsomejackuk » Fri Oct 05, 2007 2:32 pm
Keith,
Cheers on that, think I will get to couple of hydraulic suppliers tomorrow to see if I can get the required banjo bolt for now. At least until I can source the proper part. From what I understand, Keith is BSA regal no longer trading ? as I have found theese great in the past for MZ spares.
Alun
handsomejackuk
Postby keithcross » Fri Oct 05, 2007 4:59 pm
Unfortunatly BSA regal are no longer an MZ business. As far as I understand it they are no longer in teh motorcycle buisness at all, having sold off the Norton part of the group as well :(
Postby Bill Jurgenson » Fri Oct 05, 2007 11:28 pm
banjos and banjo bolt are standard hydraulic fittings. Your next-best forklift or truck hydraulics shop will have every size you can think of. They can easily press fitting onto hoses as well or make up new ones to fit.
banjo fitting
Postby handsomejackuk » Sat Oct 06, 2007 7:55 am
Bill,
I'be spent the morning going around motor factors Hydraulic stockists, Motorcross Breakers, Fuel suppliers, Pirtek, Land rover stockists, But still no luck, Have phone my local MZ dealer Bob Wilding motorcycles and they say Its probably gonna take about two weeks to get the part. All i need is m16 * 1.5 Banjo bolt and we have a postal strike for the next few days. would have thought I could pick up this part anywhere off the shelf Hydraulics. Beware when changing oil. do not over tighten this banjo 'cos it will snap !!!
Any ideas Anyone.
Alun
handsomejackuk
Postby Bill Jurgenson » Sat Oct 06, 2007 12:28 pm
if you are in the States, then M16x1,5 could prove to be a daunting problem.
banjo bolts
Postby handsomejackuk » Sun Oct 07, 2007 6:03 am
Anyone know where i can get m16*1.5 banjo bolt off the shelf U.K.
Will phone around some more hydraulic supliers tomorrow.
Alun
handsomejackuk
Postby keithcross » Sun Oct 07, 2007 4:30 pm
Might be worth trying fork lift truck places and Automotive Air con shops as well.
plug
Postby DAVID THOMPSON » Sun Oct 07, 2007 5:57 pm
Mercedes Benz Dealer for oil pan plug
or Mercedes Benz truck Dealer for something from a truck
ar dave
or a truck repair shop metric in the uk should be easy to find
now here in the usa a bit of a pain
snapped banjo
Postby handsomejackuk » Mon Oct 08, 2007 2:40 am
Thanks for your help in such difficult times. I missed going out on Baghira yesterday :cry: Just phonede pirtek in treforest, they say they have banjo there so will be making my way there shortly. will Phone bob wilding later this morning to get genuine item sent also..
Let you know how i get on.
Thanks All
Alun
handsomejackuk
