Need help. No electrical power at all. Traveller. Very Urgen
Postby FUTURE » Wed Dec 26, 2007 4:35 am
I had removed the tacho as one of the globes had come out and was
rattling around in the tacho pod. I found that the centre brass bit
on the connector that goes into the tacho for the electricity was
broken/missing. So I replaced this little bit of brass. Connected the
tacho back to the power supply. Turned the key to on. Started the
engine and the tacho doesn't work. Disconnect the connector and pull
out the bit of brass I had put in there. Reconnected the tacho.
Turned key to on and engine on switch to RUN and press starter
button. I hear a loud clunk from down near the fuses and the engine
won't start. Press the starter button again. Again a clunk and then
not power at all. Nothing. No indicators, horn, lights nothing.
I pulled all the fuses out. The 3amp one broke. So I replaced that
with a 10amp as that is the lowest that I have. I replaced the 15amp
one with a new one which I assume carries the current for starting
system.
Still a dead bike.
Anyone got any ideas? Do I have short somewhere? Does the tacho have
to be connected for power to flow to all systems in the bike?
What makes this all worse is wifes car died big time. Autotransmisson
is gone. This happened Chrsitmas Eve. And the bike is our sole form
of transport now. Gets worse pldest daughter starts first job on
Friday night and can't get there by public transport so need the bike
really bad. :-(
TIA
Ross
My Motorcycle Blog!... http://rossmz.blogspot.com
FUTURE
Re: Need help. No electrical power at all. Traveller. Very Urgen
Postby DAVID THOMPSON » Wed Dec 26, 2007 1:33 pm
ross
looking at baggie drawings i do not have a traveller wiring drawing
relay 19 it is a little gray bosch relay there is a red /black wire and a red white wire going to it
for the bike to run relay connects red/white to red black this went bad on my rt125 and i went stone dead
its pin 3 to pin5 on relay jumper them and bike should run if it does new relay needed
the 3 amp fuse supplies 12v to red/black pin 3 relay connects it to red/white pin 5 and then it goes to cdi box and starter push button
get a 3amp fuse back in there a.s.a.p.
see this for how to
viewtopic.php?f=4&t=2085
Postby FUTURE » Wed Dec 26, 2007 7:48 pm
I jumped pin 3 to pin 5 and it didn't provide any electricity.
FUTURE
Re: Need help. I sure do...Smack me in the back of the head.
Postby FUTURE » Wed Dec 26, 2007 9:52 pm
Smack me in the back of the head. I have found out what the problem with the bike was. So simple and I missed it at first. The positive terminal from the battery was loose. D!OH D!OH. When I tightened the bolt up I had power.
Thank you David for your time. I am sorry I have wasted it. Stupid me.
FUTURE
Postby DAVID THOMPSON » Wed Dec 26, 2007 11:36 pm
get you a 12volt test probe and follow the current and voltage flow battery + to fuse to other side of fuse etc.
and do carry a jumper for that relay because it will let you down one of these days
ar dave
Users browsing this forum: Bing [Bot] and 2 guests
