HIGH VS SHORT?
HIGH VS SHORT?
Postby alfredoenrique » Sun Apr 27, 2008 5:50 pm
I am a new mz baggy owner...one question...what is this "short" "tall" bike types everyone mentions here? How do i know what I have? :oops:
alfredoenrique
Re: HIGH VS SHORT?
Postby MSW » Mon Apr 28, 2008 12:26 pm
The Baghira SM comes in two versions: "Regular" and "Height Reduced" (for the inseam challenged). There are shorter forks on the height reduced model which, I believe, are not adjustable. So if you look at the top of the forks and see adjuster knobs, you likely have the "regular" version. No adjuster knobs: the height reduced.
I will probably be corrected by the folks who actually have a height reduced model, but that's my theoretical answer.
EDIT: I should note that the Mastiff also has the non-adjustable front forks, but if you can't tell the difference between a Baghira and a Mastiff by looking at it, then we have more fundamental issues.
MSW
2005 Black Panther
MSW
Re: HIGH VS SHORT?
Postby rodge70 » Mon Apr 28, 2008 1:32 pm
sounds about right as mine is an hr model with non adjustable forks,originaly enduro model,and i think the guy in the shop mentioned different dog bone length at the rear as well.
rodge70
