as long as the engine is stock, you can use the TDM box. Its limiter ist set at 8400. But its drawback is the spark advance curve which goes to 40º, more than even the extreme 38ºof the XTZ box.
these
boxes all work in the Skorpion. Both the XTZ and SZR boxes can be modified from the stock 7200 to 8400. I have modified the SZR box myself but not the XTZ which has a completely different circuit board.
OVER once offered a racing box with 5 different settings.
Slipstream tuning and
Tunebike both modify the XTZ box.
You can ask Galen Miller at
BikeWorx about box modifications.
In all cases concerning a modified Denso box, the advance curve is too extreme for very high compression ratios. 30º should be the limit for ratios above 10.5:1.
You are better off using a completely different ignition.
I suggest you try
SPARKER TCIP4 standard from Ignitech.
- ignitech_screenshot.jpg (43.63 KiB) Viewed 5182 times
You can program the CDI to suit your needs and it is plug and play as far as the connections are concerned.
I have no experience myself with this but several of my acquaintances do.
When I was still racing, I used first a PVL magneto, later changing to a SilentHektik triple spark constant loss battery ignition. Both worked fine but the SilentHektik started much more easily and had 16 different curves to choose from. The PVL had a an advance of 22º to which the static advance is added, usually 5º, making 27º total. I used the SilentHektik at 28º total advance. Neither can be used with the stock left side of the engine: flywheel and starter have to go. Back on the road and at the moment running a modified XTZ box, I can testify that the racing engine now vibrates much much worse than it did with 28º advance. I attribute this (and others in the know do as well) to the extreme 38º advance. I have not decided what to do yet, but I may get one of those SPARKER TCIP4 standard boxes as well. We'll see.
Body work?
there is really only one source in the states:
Beasley. Listed with the Ducati fairings, scroll down to MuZ Skorpion.
In Europe there is
MLB. This is what I use.
(you can just see the crank stub with the ignition rotor thru the hole in the fairing.)
Many use modified to fit Honda RS250 fairings.
Slipstream is offering or knows where to go to get a complete racing set for the Skorpion based on the RS stuff which has a big airbox instead of the tank and the tank under the seat: look thru the
gallery
