MZ Baghira - strange bolt
Postby KubaR » Mon Sep 08, 2008 2:51 pm
Hello.
I found a bolt between two metal parts - here
It looks like this -
Image Image Image
I don't know where it should be placed. I don't know where does it come from.
Please help me.
KubaR
Re: MZ Baghira - strange bolt
Postby DAVID THOMPSON » Mon Sep 08, 2008 4:14 pm
check the screws that hold the key switch in to fork
its a break off bolt the head comes off when its installed
and the loctite did not hold it in
get one same thread size with an Allen head and lock tite it in
and see if the other one is loose
edit note an other post shows a
break-bolt for the saddle-lock /seat lock ??
check them both
break off bolt.JPG (39.66 KiB) Viewed 5080 times
Postby Nils D » Mon Sep 08, 2008 6:58 pm
The Baghiras seams to be falling apart:
http://www.mzriders.com/viewtopic.php?f=3&t=2738
Nils
Skorpion Traveller 96
Nils D
Postby scholsey » Mon Sep 08, 2008 8:36 pm
Hi, I notice your forks have got a blue switch on the top of them which I take it is for adjustment ? I have an 04 Baggy but the top of my forks have no adjustment does anyone know why they are different .... might be a stupid question but thought I would ask anyway :-)
scholsey
Postby KubaR » Tue Sep 09, 2008 1:22 am
scholsey wrote:Hi, I notice your forks have got a blue switch on the top of them which I take it is for adjustment ? I have an 04 Baggy but the top of my forks have no adjustment does anyone know why they are different .... might be a stupid question but thought I would ask anyway :-)
Yes, this blue switch is for adjustment. But I don't have manual so I don't know how to use it.
My Baghira is from 2003.
Thx for all replays :-)
KubaR
Postby rodge70 » Tue Sep 09, 2008 11:05 am
the height reduced model has non adjustable forks,where as the full height baghira has the adjusters and longer forks,hope that helps.
rodge70
Postby scholsey » Tue Sep 09, 2008 1:32 pm
rodge70 wrote:the height reduced model has non adjustable forks,where as the full height baghira has the adjusters and longer forks,hope that helps.
Thanks very much ...... so how do you tell ? my seat hight seems high as is the dlearance from the seat to the back wheel ?
scholsey
Postby rodge70 » Tue Sep 09, 2008 2:57 pm
when i bought my bike in march,the only one around in black was the hr model,i only saw a difference in the angle/attitude of the bike in pics on this site, when compared to full height sm models mine seemed to be lower and pointing downwards at the front as well,probably because bike was enduro model originaly 18"/21"wheels,but 17"sm wheels fitted by dealer.found a set of forks on ebay in good condition from a full height model with the adjusters for a bargain price and now the bike rides level instead of pointing downwards and hard to say if handling has improved or compramised the bike,somebody else's view would be appreciated as the bike handles as good as it always does :D
rodge70
Postby rodge70 » Thu Sep 25, 2008 3:39 pm
must be catching,lost a stud from my ignition today and other one working loose,may try new ones with loctite as well :idea:
rodge70
Postby DAVID THOMPSON » Thu Sep 25, 2008 8:47 pm
singles seem to loose things just make sure the rider does not fall off --trust me it hurts :smt022
Postby Anna » Wed Oct 22, 2008 1:57 pm
It's "character" ;)
That and the vibrations. Loctite is your friend.
Anna
Postby MIAMIMZ660 » Sat Jan 31, 2009 9:52 pm
LOOKS TO BE A BOLT THAT HOLDS THE IGNITION ON
SAFETY NON TAMPER BREAK OFF BOLT INSTALLED AT THE FACTORY.
HAVE TO BE DRILLED OR SLOTTED TO GET OUT AND USUALY HAS RED LOCTITE
MIAMIMZ660
