Baggy fork spring replacement
Postby CasterTroy » Tue Apr 07, 2009 1:14 pm
Is there any special technique for removal of the stock fork spring and replacing it with a stiffer spring?
Is it simply removing the upper plug and pulling the cap, and spring guide out? Do I need to back out the screws in the cap top? or just leave everything in place and remove the top cap as one piece?
CasterTroy
Re: Baggy fork spring replacement
Postby rodge70 » Tue Apr 07, 2009 3:31 pm
seem to remember that you need to unbolt the spring from the cap, can't quite recall exactly what but when i done my mates fork oil last summer i had to seperate the cap may have been from damper and rebound tubes, i know its self explanatory when you see it.
there is the service info on here somewhere i think as well.
rodge70
Postby MSW » Thu Apr 09, 2009 4:52 pm
This should be all you need:
http://home.pacbell.net/adw_msw/Front_Forks_Manual.pdf
Good luck!
MSW
2005 Black Panther
MSW
Users browsing this forum: Google [Bot] and 29 guests
