Thread pitch/guage of gear lever forcing rod-Skorpion
Postby djsbriscoe » Tue Apr 14, 2009 6:54 am
Does anyone know the pitch of the thread on the gear lever forcing rod on a skorpion (marked 1 and 2 below)?
FOOTREST, LEFT.jpg (32.89 KiB) Viewed 1673 times
I ask this as I may need to shorten the rod and re thread it so as to raise the lever slightly. Is it correct that the thread on one end of the rod is a right hand thread and on the other end it is a left hand thread, or are they threaded the same?
Thanks for your help.
David.
Electronics tech by trade.
djsbriscoe
Re: Thread pitch/guage of gear lever forcing rod-Skorpion
Postby aah5 » Tue Apr 14, 2009 7:05 am
If you have run out of adjustment on the standard footrest setup,you only need to move the lever on the gearchange shaft around one tooth on the spline in the direction required. If you have changed your footrest position to the rear you will need a longer rod,that is threaded M6 x 1.00mm pitch LH & RH each end.
aah5
Postby djsbriscoe » Tue Apr 14, 2009 7:14 am
Thanks for the quick reply.
Don't know why I didn't think of that, it's fairly obvious.
Thanks.
David.
djsbriscoe
Postby Linegeist » Tue Apr 14, 2009 7:58 am
The other quick workaround if you need to shorten a rod like this, is to put a Swan-neck into it, like this ............
Linegeist
