Baggi will not start
Postby Stuart109 » Fri May 08, 2009 6:13 am
Hi
Rode my 2001 Baggi to work yesterday. When I left it would not start. Lights worked so the battery looked good, all fuses OK. Total silence from the starter button. I am thinking a problem with the starter relay or maybe a bad connection.
Before I get out the electrical tester anyone have any knowledge of likely weak spots to start with?
Stuart
Stuart109
Re: Baggi will not start
Postby rodge70 » Fri May 08, 2009 2:10 pm
as starter relay is under seat and all wires are in easy reach,check for feed there first,sorry but cant recall the colour but theres only two on soleniod.
rodge70
Postby Stuart109 » Sat May 09, 2009 2:37 am
Have had a look at the relay, no power to it but will operate if I jump power to it. So starter relay OK. Don't seem to have any power at the starter switch. andy ideas?
Looking at my PDF wiring diagram the feed to the starter switch looks to come from something called the "stop relay" (no.19). Anyone know what this is and where to find it?
Stuart
Stuart109
Postby kendo » Sat May 09, 2009 4:07 am
Check out the neutral switch , if the bike thinks that it is in gear and the stand is down then it will not let the bike start unless the clutch is pulled in.
Kenny.
kendo
Postby DAVID THOMPSON » Sat May 09, 2009 7:30 am
relay 19 is too small ground green wire if no start check red/white and red/black for voltage
one should have 12volts present
i had to replace relay 19 on my rt125
Postby BRAAAP ! » Sat May 09, 2009 11:45 am
Check the connections in the headstock, just at the front of the headstock tube in the box'ish bit at the front, mine used to cut out and it turned out to be corrosion of the terminals. . .
mine turned out the be where the ignition switch connects to the loom. The red wire has corroded in the multi block connector. . .
see post "electrics"
viewtopic.php?f=20&t=1176
hope this helps
two wheels good, four wheels bad. . . .
BRAAAP !
Postby Stuart109 » Sat May 09, 2009 11:52 am
Thanks for all your ideas.
I have managed to trace the fault to relay 19. If I jump between R/B and R/W (as suggested in a previous post) it works.
Should I replace relay 19 or just by pass it (and all the "safety" features) permanently?
What have other people done?
Thanks for yor help.
Stuart
Stuart109
Postby DAVID THOMPSON » Sat May 09, 2009 5:59 pm
replace it a rely from a auto parts supply will work just need a bigger spade on the green wire
and info is here on site
viewtopic.php?f=4&t=2085
http:// www.mzriders. com/viewtopic. php?f=4&t=2085
the short one works take the spaces out of this
Postby Stuart109 » Thu May 21, 2009 4:54 am
Thanks for all your info.
Thought I'd give you a final update.
Turned out the relay was OK and the problem was a poor connection on the green wire. Only spotted it because when I pulled off the green connection and reconnected it I felt the relay click.
Have cleaned up all the connections and now back working fine.
Stuart
Stuart109
Postby rodge70 » Thu May 21, 2009 6:30 am
hi stuart,glad all sorted,where is the relay to be found on the bike for future ref,cheers
rodge70
Postby Stuart109 » Mon Jun 08, 2009 10:18 am
Hi
The relay is attached to the side of the sub-frame behind the battery and the left side panel.
I can get to mine under the seat and without removing the side panel
Stuart
Stuart109
