Went down on my Baghira Friday
Postby Tigerboy » Sun May 31, 2009 9:43 pm
This is not the way I should start my first post :smt013
Anyway, I went down on Friday, due to my crappy front tire, that I should never have mounted. Live and learn. Results and gore at Supermotojunkie:
http://www.supermotojunkie.com/showthread.php?t=83801
Based on my accident, I'm going to need a right turn signal, right mirror and possibly a rear brake lever, if I can't straighten my bent one out. Just sprained my left thumb from all that, needless to say the accident could have been much worse both for me and the Baghira.
As there is no MZ dealer in my area, it would be nice to know if there are close substitutes for these parts that will work. If there's a dealer in the US whom I can order from, that should also work, and finally, if someone on this board has these spares, I would be grateful.
Tigerboy
Re: Went down on my Baghira Friday
Postby funmonkee » Tue Jun 02, 2009 11:55 am
Grahams is the MZ dealer I've used a few times. They are pretty good on delivery. Prices a bit steep, but you get quality replacements.
funmonkee
Postby MSW » Tue Jun 02, 2009 8:22 pm
Sorry to hear about the spill. Sounds like, all in all, you got out pretty cheap (both physically and parts-wise).
The turn signal is an easy one. It's super-universal. I have a Harley dealer right near my house, so when I break one (which is frequently) I go there and ask for a turn signal from a 2002 Buell M2 Cyclone. It's identical. The only difference is that the newer ones are not two-piece like the Baggy's, they're all one piece of the more brittle plastic (no rubber base). Also, because it's for the front, you might have to drill one hole in the new turn signal for the bolt.
EDIT: Should have mentioned that, if you don't have an easy Harley parts source nearby, there are also several models of 90s era Triumphs and Ducatis that use the same turn signal. I don't know which models exactly, but they shouldn't be too hard to find.
Because that cleat on the brake lever is bolted on, it should be pretty easy to bend back or fab a substitute. That is, unless the arm part is bent (couldn't tell from the pic). If you need a new one, the only source would be Graham's (mentioned above).
Could be the same with the mirror, although you stand a much better chance of picking up one of those used from a board member or in old stock of a former U.S. MZ dealer (most moto dealers stock upon on "perishable" parts like mirrors and levers). Call the guys at SF Moto in San Francisco and see if they have a mirror. http://www.sfmoto.com/ 415.255.3132. Tony and Mike work the parts counter, and they're terrific guys. I've picked up a few things like that from them (levers, etc.).
And, of course, there's always aftermarket mirrors.
If you have to go to Graham's, try to call them on the phone. They're nice guys, and are perfectly willing to ship to the U.S., but just e-mailing through the website, it's taken me a long time to get parts. I have a feeling that if you talk to them live, the order will get placed quickly and your parts will be on the way much sooner. That said, Graham's is legit. Genuine MZ parts and lots of knowledge about the bikes. Fair prices too.
Good luck!
MSW
2005 Black Panther
MSW
Postby OLDMTNCARVER » Tue Jun 02, 2009 11:22 pm
As MSW says, Triumph.
My brothers Triumph 955 Daytona had the exact turn signals. It was late 90's early 2000 vintage.
OMC
OLDMTNCARVER
Postby edec » Tue Jun 02, 2009 11:44 pm
My 1999 Ducati ss750 uses the same turn signals with no modification necessary, I've borrowed one before :wink:. They're about $20 each at a Ducati dealer. I managed to gently straighten out my smashed brake lever with a screwdriver, though I may just replace it with a nut and bolt someday. I've also used SFMoto for a front brake lever and was happy with them.
Ed
01 Baghira
99 Ducati SS750
edec
Postby drj » Fri Jun 05, 2009 1:41 pm
thew BMW 650GS has the exact same turn signal...should be cheap too.
the rear brake lever is cast aluminum and may be cracked now, due to your accident...be advised!
i had a similar spill on the left side two years ago, gave myself a goose egg on the wrist you wouldnt believe...i didnt notice any crack in the shift lever, and then one day it snapped off while i was riding.
take care - be safe.
drj
:mrgreen:
'03 Baghira (m4 pipe/black rims)
'01 XR650r (hotcam)
'00 XR400r (pumper/header/pipe/cam)
drj
Users browsing this forum: Bing [Bot] and 19 guests
