clutch cable
clutch cable
Postby handsomejackuk » Fri Jul 10, 2009 8:57 am
Just removed my clutch cable, as really stiff. where it passes exhaust, it has burnt away the outer casing and is bent.
Need replacement. Price for new from grahams is £23.47 anyone know if there is an alternative cable. or a better replacement. length - 1120mm. ?
would ideally like to change the clutch lever at the same time....
Thanks Alun
handsomejackuk
Re: clutch cable
Postby djsbriscoe » Fri Jul 10, 2009 10:52 am
Maybe this company can supply a replacement. They say you can send in the original and they can reproduce it.
http://www.speedycables.com/index.html
I haven't tried them myself though. Maybe we can do a group order or something as I need a longer cable myself (for my skorpion that is).
David.
Electronics tech by trade.
djsbriscoe
Re: clutch cable
Postby handsomejackuk » Fri Jul 10, 2009 5:25 pm
hi,
thanks for that, just that i was looking for a cheaper alternative, and getting one quicker. seems as though most bikes use the same clutch lever end. and most of the engine parts look similar. maybe it is just the length that is so different.
Anyone like to share some advice, as i am going to my local motocross shop tomorrow, and my local bike small bike shop that has been about for years. He says he may have something that will match up
Any clues on what bike to look for ?
Thanks Alun
handsomejackuk
Re: clutch cable
Postby DAVID THOMPSON » Fri Jul 10, 2009 10:43 pm
look at the made in Italy stuff
my Saxon Tour has a bunch of stuff thats also used on moto guzzi
and a bmw air filter from the bmw chopper fits with a homemade adapter
Re: clutch cable
Postby handsomejackuk » Sat Jul 11, 2009 10:03 am
cut out nasty bit on clutch cable taped it up with self amalgamting tape, oiled cable, jobs a good 'un.
still ought to get new one though......
alun
handsomejackuk
Re: clutch cable
Postby tonydragon » Mon Feb 22, 2010 4:16 pm
Hello all!
Hope I'm not hijacking this post....
Have you ever found a replacement?
If so, could you please let me know?
Thank You. :)
tonydragon
Re: clutch cable
Postby handsomejackuk » Sat Apr 24, 2010 12:15 pm
Tony,
no, but been told an ex500 kawasaki is similar....
Al...
handsomejackuk
Re: clutch cable
Postby edfmaniac » Sat Sep 24, 2011 11:39 pm
I can confirm that the Ninja 500 cable fits the Skorpion. It is the correct length and has a 90 degree bend on the lever end, like the cable that came with my used bike, except it is a little shorter radius. The barrel cable end that slides into the lever is a little small but I don't see any reason why it wouldn't work just as well.
Re: clutch cable
Postby DAVID THOMPSON » Sun Sep 25, 2011 2:25 am
my 660 traveller lost the end at the clutch lever
i used a clutch cable from my saxon tour
changed out the lever and perch
(a mystery part cannondale e440i think
yes i always play with odd bikes)
and used some nuts and fittings on the bottom end
from a bmw to make it work now it has adjustments at both ends
picture of fitment on request
now i only stock a saxon tour cable
Users browsing this forum: Bing [Bot] and 22 guests
