by Anders » Wed Jun 10, 2009 3:05 am
Sorry for the double post, thought it might be better to post in the 660 section as the Mechanic/Tech talk section seems to get very little activity, my mistake.
I recently came across a set of Mikuni TM34-B65 flatslides that previously graced a SZR based Supermono race bike, The SZR was not bored out but had a ported head, comp piston and a hot cam so the jetting should be fairly close to my needs since I have roughly the same setup on my -95 Skorpion.
Anyway I know the carbs will fit the intake on the Skorp but are there any other issues, apparently it hooked up directly to the SZR throttle cable set-up but are there any diffrence in this regard between a SZR and Skorpion? Do I need to modify or fab something up in order to make this work?
I'm not clear in how I will solve the intake side yet, currently I am running the airbox with no top cover using a K&N style modified filter. The Mikunis are set up fo K&N pod filters wich also came with the carbs. It looks like I can use the stock airbox if I want to, any thought are appreciated.
- Attachments
- tm34-b65.jpg (38.5 KiB) Viewed 11627 times
Anders on Tue Aug 11, 2009 9:51 am, edited 4 times in total.
In my garage:Honda VTR 1000F -00
Orion-29 125cc, Midsize
49cc Bike engine kit toy
Yamaha SRX-6 -86
MuZ Skorpion 660 -95
Polaris 6x6 Big BossNordic SRX/MuZ/SZR forum
