Throttle cable to grip linkages
Postby saxonetz » Mon Aug 17, 2009 7:39 pm
Hello all, i've just changed the handlebar grips on my z, does it matter which grooves the throttle and oil pump cables go into?, as you probably know there are two grooves, one for each , but i could'nt remember which went where . Any help would be grateful. Regards Vin
saxonetz
Re: Throttle cable to grip linkages
Postby DAVID THOMPSON » Mon Aug 17, 2009 8:30 pm
year and model helps sort out who knows about yours as it may be different i take its a 2smoker
of which i have seen only 2 --being i am located in the usa all of my 3 mz bikes are 4cycle
Postby manumensa » Fri Oct 02, 2009 5:14 pm
Hello
Cables can mount indistinctly, in my ETZ generally right groove gas and left oil pump
and no problems when I change cables side.
manumensa
