Wiring
Wiring
Postby keithcross » Tue Nov 09, 2004 5:30 pm
Saw this on another site, so it might be worth having a look.
Just a word of warning.
> My Baghira has been laid up for the past four (4) days
> because it wore through its main wiring loom, The loom
> passes over the top radiator mounting and due to vibration
> had worn through 2/3 of the wires, As you can see from the
> wiring diagram you hopefully received with your bike ALL
> wires pass over this item from the bars and headstock to
> the battery compartment. No worries its all fixed with
> some automotive wire, solder, heat shrink and some
> time......
> When this had all been resolved and I was testing the
> parts.... The ignition flickered, I checked the connection
> in the front frame support for the ignition 'plug' (five
> wires into a white flat connector) and the main feed had
> corroded causing it to fracture, fixed for now .
> The bike has done 27000 km and is ridden in all weathers.
