1974 TS250 CENTER BOLT
Postby RAYCAUGHRON » Mon Apr 12, 2010 7:07 pm
Hello,
I am a new owner two MZ TS250 bikes. Yesterday(while attempting to change the gearbox oil), and I made the mistake of removing the central-bolt on the gearbox rather than the correct oil drain screw. After replacing it and filling the oil, I found that the bike would no-longer shift gears. I removed the central bolt a second time and found the ball-bearing lodged inside the screw and the spring broken in half. I suppose I forced the bolt too much?
I was wondering if anyone sells replacement center bolt/springs and bearing?
Please let me know if you can help or point me in the right direction for these parts.
Thank you in advance,
Ray Caughron
Los Angeles, CA
rojuniorcaughron@gmail.com
RAYCAUGHRON
Re: 1974 TS250 CENTER BOLT
Postby Skorpion » Tue Apr 13, 2010 2:48 am
Hi Ray,
All parts for your ts250 are readily available here in the UK from,
Fred Rogers, Spares & Repairs, from the USA Tel 011 44 1606593638 9am-7pm UK time.
or
Julio Valdes in Miami Florida 786454 0919 Disney
He has advertised here in the For Sale section.
skorpion.
Skorpion
Postby moonzipper301 » Tue Jun 21, 2011 12:47 pm
Hello! i have a similar problem, i removed the centre bolt by mistake. i haven't put it together yet though, cause i'm now quite scared of destroying it. how do i go about putting it back in?
moonzipper301
Postby Skorpion » Tue Jun 21, 2011 1:52 pm
Hello moonzipper301.
If you havent moved the gear leaver, no harm done just replace ball bearing then the spring followed by the bolt, every thing should then work OK, the ball bearing just locates into a grove
Skorpion
Postby moonzipper301 » Sun Jun 26, 2011 4:55 am
Yes, i had a wee look into the casing with a torch, i saw this groove and noticed that it moved slightly with movement of the gear lever. So i put it back in :)
chhers
moonzipper301
