comment on chain replacement
Postby DAVID THOMPSON » Sun Jul 11, 2010 9:53 pm
i just replaced the chain and sprockets on my 660 traveller
the chain i used was a 520 regular chain and esjot sprockets 15x43
no o-ring or x ring just a plain chain
and it smoothed out the running of the bike
and improved the in town slow speed use a lot
i do about 3000 miles a year and will just remove and grease it twice a year
i put the chain in a hot tank of grease after a good cleaning
close the lid and crank the air pressure up to about 100psi
should give it a good bit in the pins at least i hope so
will see what kind of use i get from it
i am not a hot rodder so should work good
my dad had a home made chain greasing tank and i never tosssed it out
just replaced the grease
do not use a pressure washer any where near the chain if you use a plain chain
Re: comment on chain replacement
Postby basser23 » Mon Jul 12, 2010 10:03 am
Hey Dave,
Planning similar chain change...how many links did you use? 114 or 110?
Chip
basser23
Postby DAVID THOMPSON » Mon Jul 12, 2010 10:11 am
i well have to put it back up on the stand and count
forgot to do that.. but started with a 120 link new chain
will up date this later in the day
Users browsing this forum: No registered users and 0 guests
