attachments?
attachments?
Postby dthemic » Thu Feb 05, 2004 11:02 am
just trying attachments with a photo of my MZ
stock tour w/bags & windscren
Dave
'01 Skorpion Tour
Pittsburgh, Pa
dthemic
Postby 125SMash » Thu Feb 05, 2004 1:02 pm
nice :smt023
2002 MZ 125SM
125SMash
another Tour with bags!
Postby icannonball » Thu Feb 05, 2004 1:25 pm
[/img]
its nice to see what my bike would look like in Red! What windscreen are you using? This is a flyscreen from Holeshot.
2002 Skorpion Tour - blue
icannonball
Postby phlat65 » Thu Feb 05, 2004 11:16 pm
heres the back of my Baggy...
Re: another Tour with bags!
Postby dthemic » Sat Feb 07, 2004 10:58 pm
[quote="icannonball"][/img]
It's a Givi. The model is "Roadstar".Very easily removed and reinstalled. I like that. My bags are Hepko-Becker and look somewhat smaller than yours.
Dave
'01 Skorpion Tour
Pittsburgh, Pa
dthemic
Postby BAR » Mon Feb 09, 2004 3:28 pm
here's an '04 in the US :P
BAR
Postby 125SMash » Mon Feb 09, 2004 4:40 pm
vicious :-D
2002 MZ 125SM
125SMash
Postby phlat65 » Mon Feb 09, 2004 9:48 pm
saaweeet!!! Full height too :twisted:
full height...
Postby BAR » Tue Feb 10, 2004 1:10 pm
Yeah, I need it being 6'5" and all... :wink:
BAR
Postby Randy in norCal » Sun Feb 15, 2004 7:13 pm
My copper colored Tour has a National Cycle deflector shield & universal mount Maier black hand guards. I don't have any pics of it yet, but this setup protects my whole body w/wind hitting my helmet, just like I want it to. :D The whole 3 pieces probably weigh all of 2? lbs. & cost about $100 total. When I have a pic I'll try to send it here.
I also got some waterproof black tank panniers(Rev-Pack) to carry stuff & they keep my legs out of the cold wind/rain. My shins are warmed by the motor heat. 8)
`01 Skorpion Tour
Randy in norCal
Postby Brian » Fri Feb 20, 2004 1:20 am
Niiiiice.... let me at the rear fender/light..... double check those caliper bolts on the front, my dealer claims the one lower hole was slightly oversized so was the two he had in stock... had to use loc tite.... so he claims :evil: worth a double check..... :D
"Brian" 2003 MZ Baghira
Brian
Postby BAR » Fri Feb 20, 2004 1:04 pm
Yes, please ellucidate... :)
How would one go about modifying that back end to remove some of that "extra" rear fender area? There's a support bar back there about half way up the "vertical" section of the rear fender, so if you were to simply cut it (fender), you'd be exposing that bar (ugly).
Wish there was a simple way to "clean it up"...
Yeah, checked the caliper was first thing I did, after bringing it home...
BAR
Postby Brian » Fri Feb 20, 2004 1:27 pm
I will send picts today.... its easy.........later.... Brian
Brian
Postby BAR » Wed Feb 25, 2004 12:31 pm
Brian,
What's the steps to removal/modification of the back fender extension?
BAR
2003 baggy rear fender
Postby Brian » Wed Feb 25, 2004 4:46 pm
I cut the fender using nibblers (look like a drill body with small scissor like cutter) In place (not removed from bike) can use jigsaw and flat file
Took grab bars off and used 5/16" Carriage bolts (1 1/4" long) to re fasten side covers to frame at the side of the seat.
used toilet hold down(teebolts) to hold rear fender assembly to tail light assembly
I removed the tail light assembly to cut frame
I moved tailight assembly back in place to where rear light is flush with back of fender.... marked near holes with marker tip going through fender holes, drilled holes and re assembled
These aren't in order but pointers only, I'll send picts in a bit
Brian
