Engine slow to idle
Engine slow to idle
Postby mz6vicky » Mon Jan 31, 2011 2:44 pm
I have a skorpion sport cup...took a 17 mile ride and when returning I noticed when I let off the gas to come to a stop the engine
didn't want to slow down for about 8 seconds. When I pulled into my driveway going up a steep hill I thought it might cut out...
when I got to a stop and let it idle in about 5 seconds it did cut out. It was like it was out of gas or flooded. Should I just get the
carbs cleaned or is it running too rich ? It was fine for the first 15 miles....
mz6vicky
Re: Engine slow to idle
Postby billr » Mon Jan 31, 2011 8:20 pm
I'd start with a carb cleaning. When I bought my Traveller, it didn't want to run well after sitting up for a while in the owner's garage.
Rough idle, stumbling at speed.
Lots of trash in the float bowl filter.
Good luck,
Bill R
billr
Postby djsbriscoe » Tue Feb 01, 2011 3:36 pm
Also check the cables to make sure they are moving freely. A stuck choke would produce similar symptoms.
David.
Electronics tech by trade.
djsbriscoe
Postby nopantsflyer » Mon Feb 21, 2011 12:22 pm
could also be an air leak between carb and cylinder, the rubber boots, michael
nopantsflyer
Users browsing this forum: No registered users and 35 guests
