Sport 660 keep replacing spark plugs
Postby maxgain » Tue Apr 26, 2011 3:39 pm
Hi there
I have had my sport 660 die on me twice whilst trying to start. It will spin over when depressing the starter button but will not fire up. I have replaced the spark plug twice and it starts and works for a while each time. Anyone give a clue as to what may be causing this problem. I would be much greatful for any help.
Stu
maxgain
Re: Sport 660 keep replacing spark plugs
Postby DAVID THOMPSON » Tue Apr 26, 2011 5:29 pm
mine did that on the fine wire tip plugs
regular plug seems to work ok
also do not start and let idle very long
start let it idle about 30 seconds and go but not hard for the first few min.
also found the wires loose at coil a couple times the plus and minus needed new spade lugs
