Speedo reading with different wheels
Postby paul599 » Wed May 04, 2011 8:56 am
Hello,
I've just bought a Baghira dual sport, which has 2 sets of wheels; 21" enduro wheels and 17" supermoto wheels. This may be a silly question but will the different wheels effect the speedo reading? I've looked in the owners manual that came with the bike but it doesn't have anything about swapping the wheels over and at the moment the speedo doesnt seem to go above 50mph with the SM wheels on. The bike doesnt seem to have much top end, but I am used to an RF600 and 1200 bandit!
It may be the gearing set up which i will also look at.
Any suggestions/help welcome.
Cheers
Paul
paul599
Re: Speedo reading with different wheels
Postby OSPRNG » Wed May 04, 2011 11:18 am
different diameter wheels will definitely affect the speedo reading.
that aside, i've yet to see a motorcycle with an accurate speedo. everything seems to be off up or down.
if you want to know your actual speed, you could use/get/borrow a GPS or a smart phone and see what the mismatch is depending on tires, then keep that in mind when you ride.
OSPRNG
Postby kman.45 » Thu May 05, 2011 10:02 am
The SM and E model Baggi have different speedo drives, different length kickstands, and different front brake bracket. I have both "sets". The 21 wheels speedo drive returns VERY accurate speeds (comparing to GPS), within 1-2 mph. The 17 inch is pretty damn close too.
I can probably come up with the two part numbers if you think you want them.
2003 Baghira 660 SM/E
2008 Ducati Multistrada 1100S
kman.45
Postby paul599 » Thu May 05, 2011 4:34 pm
Hello kman,
thanks, that makes sense, if you have the part numbers that would be great. Thanks for our other message and picture of your bike, certainly looks good black!! Is that a universal number plate holder under the rear fender?
Cheers
paul599
Postby Skorpion » Fri May 06, 2011 2:47 am
Hi paul599,
The parts you require are to be found here
http://www.grahamsmotorcycles.com/2010% ... S_MENU.htm
Speedo Drive Gear 17'' Wheel Part No 9014597000
Speedo Drive Gear 21'' Wheel Part No 9014265000
Skorpion
Users browsing this forum: Bing [Bot] and 24 guests
