Can someone tell me what this part is?
Postby harold » Sun Jul 24, 2011 1:40 pm
I have been through all the parts diagrams that I can find, but I don't see this part in any of them. Anyone know what it is? It has some kind of wiring harness hooked to it, and it looks like a drain hose going down under the bike.
harold
Re: Can someone tell me what this part is?
Postby slammer449 » Wed Jul 27, 2011 6:25 pm
It's called a 'ventilation valve' Check user name edec for previous posts.
02 baghira- 74 rd350 piped, ported and podded. .a jetting nightmare
slammer449
Postby harold » Thu Jul 28, 2011 5:21 am
Thanks for the help. I did the search and found the thread. I had seen that on the same drawing, but couldn't tell from the drawing that it was the same part. When I tear into my carbs again, I will remove it, since apparently it is not used on other bikes. I just wished it weighed 40 lbs.
harold
Postby Old Dog » Thu Jul 28, 2011 9:54 am
I doubt it is standard as that is the fitting for the fuel pump, the XTZ vestigial part.
All the best
Old Dog
Old Dog
Postby DAVID THOMPSON » Thu Jul 28, 2011 10:25 am
On my traveller its missing
i spent a bit of time trying to figure what the extra wire
was that went to no where
Postby harold » Sun Jul 31, 2011 7:27 am
I took mine off yesterday. It is a solenoid valve. There is 12 volt going to it with the key on, and you can feel it click when it gets power. Since there was a rubber cap on the top, it was not doing anything. Now I just need to trace the wire and remove it, so I don't have a hot wire waiting to short out on something.
harold
Postby billr » Sun Jul 31, 2011 4:51 pm
harold wrote:I took mine off yesterday. It is a solenoid valve. There is 12 volt going to it with the key on, and you can feel it click when it gets power. Since there was a rubber cap on the top, it was not doing anything. Now I just need to trace the wire and remove it, so I don't have a hot wire waiting to short out on something.
Just cover it up well and save it for the power wire of that PD Oiler...or other electrical device that needs switched 12v :D
Bill R
billr
Postby harold » Mon Aug 01, 2011 5:06 am
Very good idea.
harold
Users browsing this forum: Bing [Bot] and 36 guests
