Brake light switches
Postby edec » Wed Aug 24, 2011 4:03 pm
Can someone please tell me what I can do for front and rear brake light switches on my 01 Baghira? The rear never works and the front needs to be "jiggled" just right to get it to work (intermittently at best).
Thanks, Ed
01 Baghira
99 Ducati SS750
edec
Re: Brake light switches
Postby DAVID THOMPSON » Thu Aug 25, 2011 9:58 am
front switch i think is from 1980/81 bmw r80 r65/r45 that types and years
rear is standard ktm part show old one to ktm dealer
but i use the old style spring pull type as i have blown 4 of them on the rt125
as the brake puts them under tooo much pressure and they last just days
Postby edec » Mon Aug 29, 2011 6:33 am
Thank you David for your response. As for the "old style spring pull type" you mentioned, are those different from the the ones you stated and if so would they fit the Baghira?
Thanks, Ed
01 Baghira
99 Ducati SS750
edec
Postby DAVID THOMPSON » Mon Aug 29, 2011 8:38 am
picture here you need to fix a way to mount it
good atv or mc shop should have one in stock
its just like the one i used on the rt125
http://www.rockymountainatvmc.com/produ ... kId=223678
and here
https://www.denniskirk.com/k-and-s/univ ... 210119.sku
Postby edec » Mon Aug 29, 2011 10:28 am
Thank you David for the great info you gave, I really appreciate it!
Good Luck with your own mechanical issues as well, Ed
01 Baghira
99 Ducati SS750
edec
