attachments?
fender pics
Postby Brian » Wed Feb 25, 2004 4:52 pm
You can see the rear brake light is flush with fender.....
Picture 050.jpg (66.83 KiB) Viewed 32905 times
"Brian" 2003 MZ Baghira
Brian
Postby Brian » Wed Feb 25, 2004 4:54 pm
You can see the cut of the fender in relation with the rear light, you can see the black plastic push ins to cover the reflector bolt holes. My pipe now is right up against my turn signal
Picture 051.jpg (107.86 KiB) Viewed 32904 times
Brian
Postby Brian » Wed Feb 25, 2004 5:05 pm
to the far left of the picture what you don't see is the 5/16" carriage bolts holding the cover to the frame..... underside picts next
Picture 058.jpg (105.1 KiB) Viewed 32901 times
Brian
Postby Brian » Wed Feb 25, 2004 5:32 pm
What your looking at is the lefthand side under fender... the tee bolts/nuts are all brass, to the right are the original holes, you can see the plastic pushins as well where I cut the frame
Picture 009.jpg (107.49 KiB) Viewed 32897 times
Brian
Postby Brian » Wed Feb 25, 2004 5:36 pm
#3
Picture 010.jpg (113.48 KiB) Viewed 32894 times
Brian
Postby Brian » Wed Feb 25, 2004 5:37 pm
By this picture you can see at which intersection I made the cut....
Picture 013.jpg (60.93 KiB) Viewed 32893 times
Brian
Postby Brian » Wed Feb 25, 2004 5:39 pm
The camera has a weird way of showin up stuff you do not normally notice like the skid lines of this cut.....To make the cut I took the lower fender which almost dragged on the street and used it for a template... I have since cut off excess threads etc and touched up with black to make it look factory.... I'm no craftsman but I think the job looks factory done.... the bike looks really good...
Now I have to hone my riding skills to get by that little buggar Phlat, heading into what we call turn one !@!!
Picture 014.jpg (84.97 KiB) Viewed 32891 times
Brian
sweet pics...
Postby BAR » Thu Feb 26, 2004 12:18 pm
thanks so much for posting 'em Brian, much appreciated!
BAR
Postby Brian » Thu Feb 26, 2004 12:26 pm
sorry the info is not in order but I figured you wanted the major points and since I added pictures hopefully it joined the puzzle together... If you have any questions feel free to let me know !!
Brian
Previous
