Spoked wheels, tubeless tyres
Postby paul599 » Sun Nov 06, 2011 11:25 am
Hello,
while out on my Baggi yesterday I got a flat tyre, it turned out to be a loose spoke which I nipped up. I looked over the wheel for other leaks and found a small nail but also with the help of washing up liquid, air coming from a number of spokes, where they meet the rim.
The tyres that are on the bike are tubeless Avons. This seems a bit strange on spoked wheels but I've never had a bike with spoked wheels before. I've tried to look at other posts and there is discussion about tubed tyres, rim tape, conversions etc.
Can anyone give me some advice on using tubeless tyres on spoked wheels and does this wheel need an overhaul etc. ???
Paul
paul599
Re: Spoked wheels, tubeless tyres
Postby DAVID THOMPSON » Sun Nov 06, 2011 12:22 pm
i have always used tubes on spoke wheels except the
bmw rim where the spoke ends up in the lip of the rim outside the tire
my 1995 MZ Saxon Tour has alloy rims but needs tubes. the rim shoulder is not shaped for tubeless tire
there are some rubber sealers now that will seal the spoke but they need to be a flexible type seal
and not become totally hard
but make sure bead edge of rim and tube fit each other for tubeless use
Postby Baggy_Al » Mon Nov 07, 2011 4:45 pm
Hi Paul, I`m with Dave on this, I run tubes on my Baggy, its a lot less hassle.
Al.
2003 Baggy Black Panther.
Baggy_Al
Postby paul599 » Mon Nov 07, 2011 6:28 pm
Hello,
Yes it has a tube which I have had replaced. Thanks for the replies.
Headlight gone now, HID conversion, not cheap!
paul599
Postby chisleu » Tue Nov 08, 2011 7:06 pm
I had a new tire installed today and the guy reused the tube (I would have preferred a new one) and it ended up getting a crease in it when he installed it and it started losing air. Had to have them pull the tire again and replace it. :(
At least they only charged me for the tube, not another $60 install.
I don't know what convention is, but I would install a new tube with a new tire.
chisleu
Postby Baggy_Al » Wed Nov 09, 2011 12:52 pm
How much :shock: I hope that wasn`t to a loose wheel.
Al.
Baggy_Al
Postby chisleu » Wed Nov 09, 2011 6:33 pm
Baggy_Al wrote:How much :shock: I hope that wasn`t to a loose wheel.
Al.
They put a crease in the tube when they installed it. They didn't charge me to R&R the wheel. He just pulled it and installed a tube for me ($15ish)
chisleu
Postby DAVID THOMPSON » Wed Nov 09, 2011 6:49 pm
i always did my own on the tube type
but the rt125 and traveller i had a shop do them
as i had big time problems doing the tubeless ones on the rt125
and will not ware out enough tires to cover the expense of a tire machine
in the future
Postby chisleu » Wed Nov 09, 2011 9:15 pm
DAVID THOMPSON wrote:i always did my own on the tube type
in the future
I can't afford any more toys! haha.
I don't mind paying for hard stuff to be done, but carb cleaning, and such is doable.
I ordered a baghira/mastiff 15/50 sprocket set from germany and a DID X-Ring chain from the US. Have to hunt a install guide. I guess I just pull the rear tire and that cover off of the front sprocket. I hope it's not too hard!
chisleu
Users browsing this forum: Bing [Bot] and 37 guests
