Perfect fit. SV1000 front pad into the grimeca caliper of an 01 mz skorpion.
The bolt hole had to be drilled out about 1/32 of an inch and there it goes.
Cool.
Srinath.
Srinath wrote:Ha ha ... you're making me think sacreligious thoughts ... see the 98 and later katana 600 and 750 had the same 41mm forks and spacing within 1/8th of an inch. I have thought long and hard about tossing the MZ forks and dropping the whole fork legs, calipers, brake discs - yes plural - have twin discs and wheel and fender into the triples of the mz. Katana forks also have rebound adjustment. And to cap it off the katana rear wheel is a 4.5" which looks like it would drop into the MZ swingarm with very little fuss.
What is preventing me ... the MZ I got has nothing wrong with its forks and I cant justify dropping 3-400 in the FE and rear wheel for no reason. More over, the 98+ katana has single action calipers. 89-96 katana has dual opposed pistons but its ~1/2 inch narrower c/c distance on the forks.
It would be a choice for me ...
Then the twin disks and weight etc etc ... probably, but really not enough to make a difference. I can tell you however that twin disks get the front end twisting less under braking especially.
Users browsing this forum: Google [Bot] and 49 guests
