Coil Wire
Coil Wire
Postby basser23 » Sat Jun 09, 2012 2:30 pm
Does the plug wire on a Skorpion coil unscrew (wire only) or is there a removable screw on type cap to hold the wire in?
Mine looks as if its molded to the coil....want to replace the 16 year old wire...
basser23
Re: Coil Wire
Postby Ratbag » Sat Jun 09, 2012 9:08 pm
I didnt check mine when I rebuilt the mount...but i'd reckon on a new complete coil.
Ratbag
Re: Coil Wire
Postby Skorpion » Sun Jun 10, 2012 3:00 am
Looking at the parts diagram it looks like its a separate part.
http://www.grahamsmotorcycles.com/2010% ... ectric.htm
Skorpion
Re: Coil Wire
Postby Bill Jurgenson » Sun Jun 10, 2012 4:01 am
if it is the original DENSO coil, then the lead is screwed in.
get a NGK CR3 racing lead:
http://www.ngksparkplugs.com/products/performance/racing_wires.asp?mode=nml
Re: Coil Wire
Postby basser23 » Sun Jun 10, 2012 9:56 am
Thanks all...
Bill that is the lead I have...there is no screwed on cap on mine,but I have to believe it is the original coil,,so just the wire would be screwed in correct?
Chip
basser23
Re: Coil Wire
Postby Bill Jurgenson » Sun Jun 10, 2012 1:00 pm
yes, screwed in. look into the connection.
I didn't say anything about a screwed on cap.
Re: Coil Wire
Postby basser23 » Sun Jun 10, 2012 10:36 pm
Thanks Bill
basser23
Re: Coil Wire
Postby hutchy » Tue Jun 12, 2012 4:12 pm
has anyone fitted a stick coil as a replacement, if so what bike did it come off and did it make much of an improvement?.....Cheers
hutchy
