ETZ luggage rack
ETZ luggage rack
Postby mirmay » Thu Jul 19, 2012 4:33 pm
Does anyone know if the luggage rack advertised on Ebay as being suitable for ETZ250 will fit the ETZ125?
http://www.ebay.co.uk/itm/MZ-ETZ-250-TS ... 27c93b62e0
or
http://www.ebay.co.uk/itm/MZ-ETZ-250-re ... 3378d9aca5
mirmay
Re: ETZ luggage rack
Postby Trogolodyte » Fri Aug 03, 2012 4:36 pm
should do, i had a Etz125 and managed to fit an early etz250 rack on it... worked fine
Trogolodyte
Postby mirmay » Sat Aug 04, 2012 2:45 pm
Thanks for that. Just for interest, are the 250/125 frames the same with diferent mechanicals or is the 250 frame larger?
mirmay
Postby Trogolodyte » Sat Aug 11, 2012 7:11 am
the etz 125 differs from the earlyer etz 250 in that the swing arm on the etz250 is slightly wider and longer to accomodate the larger 18inch wheel and the rear frame is different as it has a different mudguard to the later model camel tank 125 & 251/301's. i also think that the 125 's spine frame just behind the top engine mount is not so heavily re-enforced as the 251/301's but i may be wrong on that
Trogolodyte
