taking off Mastiff`s swingingarm
Postby ericetz301 » Mon Aug 13, 2012 5:46 am
hi folks, collective wisdom required.
how easy / difficult is it to take the swinging arm off a Mastiff ?
I had the cushdrive bearing collapse and the sprocket fixing bolt heads have cut a goove in the swinging arm :( :( :x
any advice would help.
ericetz301
Re: taking off Mastiff`s swingingarm
Postby DAVID THOMPSON » Mon Aug 13, 2012 7:16 am
may not be exactly the same. But this will get you started
http://www.totalaptitude.com/skorpion/Page%201.htm
this was posted a few days ago on the sight
and may i recommend a work stand at least knee high
and tie it to a point in ceiling so you don't knock it off on your self
Postby Linegeist » Mon Aug 13, 2012 2:49 pm
DAVID THOMPSON wrote: ................. and tie it to a point in ceiling so you don't knock it off on your self
If you posted the link to the first page of the stripdown, you'll notice that I recommend you do exactly that ...............
Skorpion Stripdown
Bob
Linegeist
Postby DAVID THOMPSON » Mon Aug 13, 2012 4:02 pm
thanks for the up date on the link
my source only started at page 2 and i could not find the start
Postby ericetz301 » Thu Aug 16, 2012 5:37 am
Dave,
many thanks for the advice, and the link was very useful. :D
ericetz301
Postby Thunderinhell » Tue Aug 21, 2012 11:59 am
hi its not that difficult mate
Get a motorcycle lift and jack d bike up till the rear is just off the ground.
Soak the Nuts and Bolts connecting the swinging arm, dog bones and rear shock in a releasing fluid with a high creep capacity (something like WD-40)
Undo the wheel and rear brake.
Slide d wheel forward till u have enough clearance to slip off the chain and remove the wheel.
Undo the dog bones and tap our the retaining bolts
Undo the rear shock's bottom mount and tap out the bolt
Undo the main swinging arm retaining bolt and tap it out from right to left (looking at it from rear)
It's a good idea to check and replace bearings if needed at this stage as the needle bearings used are not of the best quality imaginable and have a habit of falling out.
Re-assembly is the reverse of the above !
Hope it helps mate !
Thunderinhell
Postby ericetz301 » Tue Sep 18, 2012 5:50 am
hi folks,
thanks for all the tips and advice, especialy about the swing arm bearings. :D
ericetz301
Users browsing this forum: No registered users and 131 guests
