Front Brake Lever Problem
Postby pinhead1990 » Wed Aug 15, 2012 3:22 am
I was riding home from work and managed to lose something from my front break lever. ( Images Attached)
I'm not sure of what the part name actually is called to order another
Are they usually expensive to replace?
hope someone can shed some light on this thanks
pinhead1990
Re: Front Brake Lever Problem
Postby DAVID THOMPSON » Wed Aug 15, 2012 10:26 am
your bike appears to have fallen over and bent the lever
but the lever angle tells me it may have busted the mounting point for the brake lamp switch
or sheared off the mounting/pivot screw
grahams motorcycles in the uk has the parts get ready to dig real deep in your pocket for the parts
Postby radiograf » Thu Aug 16, 2012 1:54 pm
Looks like it could be part number 21 "pressure bolt" on the Baghira/mastiff parts diagram.
Although your lever looks bent on the photos I suspect that is down to using a very wide angle lens, causing barrel distortion.
radiograf
Postby pinhead1990 » Thu Aug 16, 2012 4:20 pm
radiograf wrote:Looks like it could be part number 21 "pressure bolt" on the Baghira/mastiff parts diagram.
i thought that might of been the name of the part, looks like ill have to give grahams a ring again
yeah that's right i used a gopro to take the pic's, wide angle lense does seem to distort images quite a lot.
Thanks for your help
pinhead1990
Postby DAVID THOMPSON » Thu Aug 16, 2012 5:19 pm
inspect the lever at point 1
and the m/c body at 2
where the brake switch mounts
and see if there in order
i got 2 of those stroke adjustment screws in my last order and it strikes me they were a bit longer then the original one..
it appears your lever can swing back farther than on mine ??
Postby pinhead1990 » Fri Sep 14, 2012 6:46 am
Thanks for your help guys it was the " Pressure Bolt " i needed...
Managed to get one for just under £5 at grahams :lol:
pinhead1990
Postby handsomejackuk » Fri Sep 14, 2012 1:41 pm
Glad u got it fixed it looks a bit shabby though.. that master cylinder cap polishes up real nice.... hope havent offended....and those bolts are rusty
Those mirror bracket clamps can be reversed up side down too...if you dont use mirrors.
Dont listen to me
I is a bit cheekyy
handsomejackuk
Postby pinhead1990 » Mon Oct 01, 2012 8:39 am
handsomejackuk wrote:Glad u got it fixed it looks a bit shabby though.. that master cylinder cap polishes up real nice.... hope havent offended....and those bolts are rusty
Dont listen to me
I is a bit cheekyy
Don't worry I'm not offended, I've had it a good few years now..
Unfortunately I don't have a garage to keep her dry in. I could really do with putting some time and effort into getting her cleaned up really nice before I pass her on to someone else.
pinhead1990
Postby DAVID THOMPSON » Mon Oct 01, 2012 11:41 am
take my idea and keep it
mine is set to be part of my estate sale
there is a sticker on the tac says
do not ask if its for sale
Return to 125 cc
