ETZ251 Changing gearbox oil
Postby stuart-glos » Sun Aug 19, 2012 12:57 pm
I managed to get the Kanuni ETZ251 engine into the frame, spent some time cleaning the carb, put on the wiring loom, etc and it started first kick!
I now want to change the gearbox oil - should be a simple task but I wanted your advice.
There are two drain plugs under the engine - are they both for the gearbox?
I think I need SAE90 oil for the gear box?
How much do I put in? The Haynes manual talks about a level hole by the clutch on a 150 & a 250 - but I'm unsure about a ETZ?
thanks
stuart
stuart-glos
Re: ETZ251 Changing gearbox oil
Postby Skorpion » Mon Aug 20, 2012 4:12 am
Stuart.
Only the large bolt nearest the exhaust is a gearbox drain, the other is the gear selector detent spring, ball bearing, holder, do not undo this.
The lower clutch casing screw, below the gearchange lever is the drain for the clutch side of the gearbox, oil level is the screw behind the gear lever.
SAE 75/80 GL4 light gear oil
Skorpion
Postby radiograf » Mon Aug 20, 2012 1:14 pm
Watch out for "friction modifiers" in some oils, as these will cause your clutch to slip.
radiograf
Postby atreyu » Tue Aug 21, 2012 7:01 am
Silkolene light gear oil is what all the racers use, and its not overly expensive.
atreyu
