WOW WOT A DIFFERENCE !!!!
Postby handsomejackuk » Fri Sep 21, 2012 1:23 pm
as topic says... wow wot a difference... i changed my plug last nite as it looked a bit grubby. also give my airfilter a good clean... then took off th tank... removed the carbs, and give them a thorough clean.... seperated the both carbs too, and cleaned every orifice, and all the bodies...they were in despearate need of it too... it took me all of 6 hours to remove them clean them and reinstall them... took it for a spin felt the same as before but slightly more responsive... throttle... there was a bit of sandy grit in the float bowl, but nothing too much to worry about....
i also turned that knob on the top so as the secondary carb opens a bit sooner did about 2 turns on it... wow wot a difference.. this makes it just seems so much peppier, and so much more responsive on the throttle...
i think i may need to do the other mods to the carb now with the jets... any advice on this would be well received
handsomejackuk
Re: WOW WOT A DIFFERENCE !!!!
Postby handsomejackuk » Sat Sep 22, 2012 4:05 am
Is this 6mm spacer under the primary and set the secondary to open by this still the proper way to adjust the carbs? ??
handsomejackuk
Postby harold » Thu Sep 27, 2012 5:06 am
I replaced the pilot jet with the one size larger one that is the only one available. I then reamed it out with a welding tip cleaner. That helped low end response. I ended up putting a 42 Mikuni on it, which you can read the posts to see the hassle that caused, but again- it made a difference. Went from not being able to get the front wheel off the ground in first, to being able to pull it up in 2nd if hit just right. The 11/1 piston and stage 1 cam didn't hurt either.
harold
Postby Srinath » Mon Nov 19, 2012 12:53 pm
42 mikuni's, I thought the right size was a 40, and you should hack off the tip of the mikuni's, ~2mm should do plenty. The original length will hit the carb body too much ... or it did on my skorpion.
Cool.
Srinath.
Srinath
Users browsing this forum: Bing [Bot] and 36 guests
