Pannier options for ETZ 251
Postby treehouse » Fri Mar 22, 2013 12:52 pm
Does anybody know what panniers I can fit on my 251, which has a rack, but I don't know what sort. I'd like them to be cheap - so probably s/h - about 35 litres or more, and locking (with key or combination). I'm not bothered about them locking to the mount. Alternatively, I'm thinking I might fit a pair of old panniers with homemade brackets. Old fibreglass ones like Cravens look like they might work, maybe with some additional strengthening.
I'm also wondering if it would be good to mount any larger panniers low, using the available height between the seat level and exhaust, since low-down weight ought to be more stable, and getting the tops flush with the saddle might be handy for a roll bag, but since the rack doesn't have any ironmongery lower down by the wheels, do I need to change the rack or add anything, or do you think it would it be better to mount them higher? Are there usually any insurance issues to consider in making your own panniers or bolting some on that weren't made for it? Any expert opinions or wild guesses gratefully received! Or panniers, of course!
MZ ETZ 251 Saxon Rack.jpg (25.15 KiB) Viewed 8239 times
I got a blue one to go with the smoke
treehouse
Re: Pannier options for ETZ 251
Postby andy1141 » Sat Mar 23, 2013 4:24 am
I have hepco and Becker panniers on my saxon 251 and traveller they are well made ask any skorpion traveller owner.
You would have to remove the plastic sidings and grab handle .
They fit on the pillion foot rests ,spare holes by shockers,the holes where the seat is bolted on and a bracket behind the reg plate which join the frames together. There is also lugs on frame to put indicators on.
If you google hepco and Becker they have PDF for you to see.( don't know how to create link sorry)
I have also seen other makes of pannier which have been put on .
Andy
andy1141
Postby treehouse » Sat Mar 23, 2013 8:26 am
andy1141 wrote:I have hepco and Becker panniers on my saxon 251 and traveller they are well made ask any skorpion traveller owner.
Ah, that's good - I've been wondering whether I can remove the grab handle. I'm always looking for ways to shave a few grammes off.
That's really useful info, too, andy1141, thanks.
Andy
Yeah, they look ace. Only problem is the cost is way more than I want to spend, like by a factor of 10! The frame alone is £221, and a pair of panniers about another 3 or 4 hundred. I may have to bolt some s/h panniers or flight cases on instead, but even those are going for (my version of) "silly money" on ebay. Yes they'll break and scatter stuff all over the road if I fall, but I'm not planning on falling. :-D I'm even considering some cheap plastic boxes, like fishing tackle / seat boxes, locked with padlocks. I'm a cheapskate, that's why I got the bike I got. :lol: Cheers.
treehouse
Postby andy1141 » Sat Mar 23, 2013 1:12 pm
II was lucky I had frames with bike and panniers same as skorpion
If you see some panniers and frames going they might only need brackets moving ,throw overs are ok and you've got a good rack.
Andy
andy1141
Postby LANDSURFER » Sat Mar 23, 2013 3:46 pm
I'm currently making some nice plywood panniers. I'll drops ome pics on tomorrow. They fit to the side of a standard ETZ rack.
The road goes on forever.
To be anti war is human.
To be anti British Soldier is unacceptable.
LANDSURFER
Postby therealche » Sat Mar 23, 2013 5:00 pm
Got a mate with a Harley with panniers made out of plastic expansion tanks like this but not as fancy!
http://www.diy.com/nav/fix/plumbing/plumbing-supplies/water_tanks___cylinders/Polytank-10-4-Expansion-Cistern-Black-9414885?skuId=9705590
Works on the principle that they are designed to keep water in, they should keep the water out! ( The Harley also has a stainless steel exhaust system, made out of premade bends and tubes, and home welded together! Looks bloody awful... but it was cheap!)
Always worth thinking laterally!
therealche
Postby Norman Wade » Sun Mar 24, 2013 4:44 am
Article on the MZRC website on making plywood panniers: http://www.mzridersclub.com/html/woodenpanniers.html
Norman
Norman Wade
Postby Norman Wade » Sun Mar 24, 2013 5:12 am
I have seen ex Army food boxes used as panniers. Known as 'Norgie Boxes' due to being first used by the Norwegian Army, these are used by the British Army for carrying food out to the field and are sold off through surplus shops.
Although they are referred to as '18 litres', they have a thick thermal liner, which if you cut it out would increase the capacity to around 35 litres. Completely waterproof with a snap down lid, they are very robust. There are videos on the Web of people running them over with military vehicles!
Supply is sometimes difficult and they vary a lot in price, but I found two suppliers: http://www.armysales.co.uk/field-catering-cooking-utensils/18-litre-norwegian-food-container-grade-b and http://www.ebay.co.uk/itm/18-Litre-Norwegian-Thermal-Food-Drinks-Container-EX-British-Army-Grade-C-SALE-/370737018425?pt=UK_Collectables_Militaria_LE&hash=item5651a5f639
Good luck!
Norman
Norman Wade
Postby treehouse » Mon Apr 01, 2013 6:47 am
Thanks for all the great ideas. I've just ordered my "panniers". I'll post again as I make progress fitting them. I've done a fair bit of research and might as well share my other ideas in case it's of use to anyone else thinking of making panniers from other stuff. Warning - long essay follows! :smt006
I looked at moderate size boxes, roughly 40 cm wide, 35 cm high and 20-25 cm deep, and as light as possible without compromising strength too much. I decided I wouldn't discount side-opening ones, but I'd prefer top-openers.
And this is what I've settled on using:
Keep your luggage in alphabetial order?
box file.jpg (11.52 KiB) Viewed 8141 times
http://www.amazon.co.uk/gp/product/B004 ... iceproduct
They're about £20 in the shops and online, but I noticed amazon are selling them at £12 each, although temporarily out of stock. I'm not in any great hurry, so that'll do me - £24 a pair is a bargain for some metal top-opening panniers! They're not exactly Ard Cases, and there will be some fettling to do. The plastic strap handle is popped through two holes in the lid, so I'll put a piece of aluminium plate or something over the top (after removing the handle), which would also stiffen the only part that's a bit wobbly (I've looked at them in W H Smiths), and then I'll probably add some bungee attachment points. The main section seems fairly rigid, and would be waterproof with a bit of glue or sealant down the corners - they're basically just bent steel. The lid and base meet with a flat edge several mm wide, which could take a thin layer of something to seal it. I'll probably strengthen the back internally.
The clasp and lock are so cheap and nasty that locking it would probably only ensure it stays closed in transit! They will need some aftermarket locks, under a tenner for two. I'll use either a 1/4 turn cam lock, which could latch onto a bar inside the lid, but there's a small chance of something inside fouling it and stopping it unlock, or an external hasp with an integral lock (I don't really want padlocks rattling). The latter have the advantage also that they fold over their own fixing screws when closed, whereas the bracket for the cam would leave bolt heads on the outside that would need covering somehow.
Other tweaks will include a rounded flight-case corner thingy or two (I may have some in the shed or I can knock something up) - to make the panniers a bit safer in use and avoid the sharp corners ripping my bike cover - and some padding inside (cut up cardboard box and blue-tack will do the trick and be replaceable every now and then).
They should work out at about 22 litres each, which is a bit smaller than I first wanted, but not a bad compromise considering the cost, weight (2.5kg-ish each) and the lower aero drag. They should just fit ok without remounting the indicators. You can get silver and other colours.
Now, other contenders -
If you're going for strength and waterproofing, these heavyweight tool boxes/flight cases from Duratool look great:
http://cpc.farnell.com/1/1/47578-waterp ... atool.html (and there's a smaller one, the 467).
They require a padlock to secure them, but you probably can't get much tougher plastic than these. Pressure valve. Waterproof seal and padding included. The downside for me is they're heavy (although the data is wrong and says 9 kg for the big one, when it's actually 5.6kg - I asked them to weight them - and the smaller one is 3.4kg). I don't want to lug 7 kg of empty box around, personally. They're a little over £50 for the pair, since at the moment on that site orders over £45 are postage free! (And they'd cost you nearer £90 a pair on some sites I've seen.) The data is all a bit off - virtually nowhere is there a correct picture of the 468 - they all show the 467 - so I googled and found this (note, even on the product itself there's a picture of the wrong box!). It has clasps down each end as well as two on top:
duratool 468sm.jpg (68.71 KiB) Viewed 8141 times
An LP flight case is about the right dimensions (an LP is about 32 x 32 cm). The ones holding a nominal 50 look a good width. There are quite a few different types.
This is a sleek-looking thing http://www.amazon.co.uk/RECORD-BOX-ALUM ... p_t_3_TBQ0
...the weak point probably being the locks, but they might just deter the casual thief. £65 a pair - craaaaaazeee money! It looks like the closure has enough width to put some better waterproofing in, although the sections of aluminium and plastic might leak between them. One potentially useful thing with this is that once open, the top lifts right off.
Here's another, tougher-looking and heavier at about £90 a pair http://www.amazon.co.uk/Euro-Style-Reco ... p_t_2_TBQ0
Instead of having a pointless lock, this has a more solid-looking clasp that you could padlock, which might be a lot more secure if you can stop it rattling. Again, there are places water might seep in.
Something in between http://www.peripheralcentre.co.uk/cd-dv ... for-50-lps
This is the cheapest LP case I've seen (other than PVC covered cardboard ones!) - two, with shipping, comes to £53.50. Again, two relatively useless locks, and they're probably in the region of 3.5 kg each.
For something really cheap, you might consider these plastic suspension file boxes
http://www.ebay.co.uk/itm/Pierre-Henry- ... 416824965d
...and why would you buy one at £8.99 plus £2.95 economy delivery when you can pick one off the shelf at WHS for £8.62? Yes, that's £17.24 for a pannier set! There are quite some drawbacks tho - the sides flex quite badly when the lid is open (although when it's closed they are pretty stiff) so they'd probably need something to stiffen them and transfer load to the rack - aluminium bar or something round the inside. It has the handle through the top like the metals ones I'm getting, so that would need plugging, but worse, the lip is very narrow and almost impossible to waterproof. Probably the best way to waterproof these is forget all the gaps in the lid and stretch an elasticated rain cover over the top - the rest is snug as a bug. The depth starts at about 24 cm at the lid, but the front and back slope and the lower 3/4 of the box is only about 20 cm. The sides slope too and have integral handles in the walls, so they're on the small side. The clasp closes (very positively, actually) onto a small tab of the base with a hole, which could take a small padlock. The plastic is pretty thin, so it wouldn't take a lot to cut through it. But if you were after some dirt cheap ultralite panniers and don't have much worth nicking, these might be just the dogs.
Beyond that in the cheap stakes, there are "really useful boxes" of various sizes - like tupperware - for going to parties? :lol: One interesting idea I had was a collapsible box, but I didn't find any suitable - the idea being that if you fix the bottom to your rack, then when they're not in use they can be folded into the side of the bike to reduce drag. I thought long and hard about these, which could be fixed so that the little trap door on the end was the opening, and the "top" would be glued on permanently -
...but it would take so much to strengthen them, waterproof them, add locks and paint them, it's not worth the hassle.
treehouse
