edfmaniac wrote:I discovered that as well. Buy another one for a backup because mine didn't last but about a year. I was putting 10,000 miles a year on it then though. Yours might last longer.
DAVID THOMPSON wrote:and they STILL mess it up!
and the only time your in trouble is when the wife and your girl friend get along with each other.!
radiograf wrote:Can I recommend that you apply chain lube to the point where the cable enters the lever. If this seizes the cable will flex and work harden, eventually causing it to snap. I use chain lube as it sprays on thin and then thickens, so it enters the joints easily. Its also fairly waterproof
Users browsing this forum: Bing [Bot], Google [Bot] and 48 guests
