CANT GET 74 TS 250 STARTED
Postby N1YDP » Sat Apr 13, 2013 6:58 pm
igot a 6 volt battery for it. it is one of those small ones like a moped takes.i have blue spark but i have to put my hand over it to see it.would it be because the battery is to small.?
N1YDP
Re: CANT GET 74 TS 250 STARTED
Postby davegsm82 » Sat Apr 20, 2013 7:48 am
Not likely, if you have a good spark, in the right place, and enough fuel then you should have ignition.
Is the plug wet (fuel) after a good few kicks of the starter?
Your plug-cap could be breaking down under load (engine compression) and leading to no starting.
Dave.
davegsm82
Postby N1YDP » Sun Oct 06, 2013 1:13 pm
have good spark,compression about 135,battery at 6 volts with key on.i put some gas in the cyclinder and it still didnt fire.i am using my weed wacker mixes gas,that shoulnt be the problem should it?
N1YDP
Postby N1YDP » Sun Oct 06, 2013 3:36 pm
found the problem.i think i need a bigger battery,i have a 6 volt 4a battery but i dont have the alternater hooked up.i am running it direct to the coil.if i hook my battery charger to in it runs great,but when i unhook the charger it runs for about
5 seconds and dies.if i get the alternater hooked up would that battery work.
N1YDP
Postby N1YDP » Sun Oct 06, 2013 4:04 pm
yep! need bigger battery,need a 6n11a1b.4 amps wont cut it
N1YDP
Postby DAVID THOMPSON » Sun Oct 06, 2013 9:44 pm
its not going to be cheap as they do not sell a lot of 6volt MC batteries any more
Postby N1YDP » Mon Oct 07, 2013 6:56 am
$28.00 shipped with acid.love ebay.
N1YDP
