Correct Tool ?
Correct Tool ?
Postby MichaelTorre » Fri Jun 14, 2013 2:55 pm
Taking the clutch off of my TS250 was quite-the-chore.
I borrowed a big 3 jaw that was new, 7 ton capacity and it took all
I had to crank in the torque to get it to pop. ( bang, actually).
Now I find you MZ folk use a threaded tube and a bolt.
I only copied the Hands manual.
Could I have damaged the clutch?....... the jaws fit well.
I now see the Kiasers manual uses a tube and bolt arrangement.
M-
MichaelTorre
Re: Correct Tool ?
Postby mr_luke » Sun Jun 16, 2013 3:26 am
Hi Michael, I have heard tales of clutch baskets being bent by the use of 'normal' pullers. Hopefully you will have got away with it though. Perhaps it would be worth putting the clutch back on (once you've bought the proper tool to take it back off again with!) and checking that it still runs true, perhaps even using a dial guage if you have one? If you do turn out to need to replace it, I [i/]believe[/i] the ES 250, four speed TS 250, Supa 5 and all the 'big' ETZs, Saxons and Kanunis all share the same clutch, so the bits shouldn't be too difficult or expensive to find.
mr_luke
Re: Correct Tool ?
Postby stogadog » Sun Jun 16, 2013 2:52 pm
The proper puller is only about a tenner from the MZ shop or there are usually a few on ebay. Be worth investing in one
stogadog
Re: Correct Tool ?
Postby therealche » Mon Jun 17, 2013 5:51 pm
I am sure that the puller for the ES is different to the one for the ETZ... think the TS uses the same one as the ES.
therealche
Re: Correct Tool ?
Postby MichaelTorre » Tue Jun 18, 2013 9:14 am
thanks for pointing out the possibility of damage.
Hidden damage can be a real heart ache if undetected.
Durn manuals used the wrong technique.
I will check for true running.
Michael
MichaelTorre
Re: Correct Tool ?
Postby DAVID THOMPSON » Tue Jun 18, 2013 4:26 pm
find a deep trash bin for the haynes manuals
i learned this with the one that came with my first bmw over 40 years ago
