Baghira MOT question - discs
Postby Tonyf » Mon Apr 07, 2014 9:28 am
Baghira's in for MOT on Saturday. Does anyone know the disc thickness specifications and whether there's a pass / fail associated.
Front Disc is just over 5mm, rear is just over 4mm.
Tonyf
Re: Baghira MOT question - discs
Postby den » Mon Apr 07, 2014 12:37 pm
hi , from experience i very much doubt they will even look , as long as its clean, looks serviced and it passes the brake test then all will be fine,,
usually a large lip or score marks may catch his eye but only to investigate brake pads,,good luck
den
Postby Tonyf » Mon Apr 07, 2014 1:38 pm
Thanks Den. Local dealer takes satisfaction out of advisories... Let's hope it passes.
Tonyf
