2002 Skorpion dies without choke
Postby Antrap9 » Thu Jul 10, 2014 1:33 pm
Cleaned and reinstalled carbs. Original problem is now solved; motorcycle throttles without stalling, however will now stall when choke is turned off. Does this mean I'm running too lean? I am also worried I missed something upon reinstallation, noticed air escaping from a valve on the breather hose...
Antrap9
Re: 2002 Skorpion dies without choke
Postby DAVID THOMPSON » Thu Jul 10, 2014 5:16 pm
some have had problems with the tank shutoff valve restricting the fuel flow
and some of the 660 bikes had a fuel pump installed on the motor that was not needed
when the 660 motor was installed on the MZ bikes
not felling well to day .. i will try to get you a picture of the carb plumbing
on my 1997 traveller later to night or friday
need for the day to cool off befor i go to the shop
the humidity here is killing me this week
Postby Antrap9 » Fri Jul 11, 2014 8:12 am
Thanks!
Antrap9
