Home made Handguards MZ Saxon Tour
Postby paulatradese-6 » Sun Sep 14, 2014 8:14 am
Got fed up with cold hands and no handguards would fit. So Made my own.
Clamps and plastic are from cycra, probend.
Bent some Wickes 14mmx5mmx1m flat bar into a nice curve using an old fork stantion.
paulatradese-6
Re: Home made Handguards MZ Saxon Tour
Postby DAVID THOMPSON » Sun Sep 14, 2014 10:35 am
the real advantage to these is every time mine falls over it breaks a lever
no other motorcycle brand in the usa uses this lever
and postage for a couple levers is almost as much as the levers :smt021
Postby MZCountryRider » Mon Sep 15, 2014 8:56 am
DAVID THOMPSON wrote:the real advantage to these is every time mine falls over it breaks a lever
Are you sure? The clutch lever appears to be the same as some Moto Guzzis. Perch and lever on both (Rotax) MZ and later Guzzis are made by Domino.
Good job on the handguards! I managed to fit a pair of Acerbis Rally to my Saxon County back when, but it was really tight.
Charlie
'69 Guzzi Ambassador
'71 Guzzi Ambassador
'72 Benelli 175 Enduro
'73 Guzzi Eldorado
'76 Guzzi I-Convert
'77 Morini 3 1/2 Strada
'81 Ducati 500SL Pantah
'82 Moto Guzzi V50 III
'97 MuZ Skorpion Tour
MZCountryRider
