Replacement ignition key
Postby Bertram » Wed Jun 24, 2015 7:23 pm
Members: Can the ignition key be replaced at a neighborhood locksmith store. Or do I need to contact a dedicated MZ vendor. Are there other brands of motorcycles that use the same key blank. Also is the Rotax engine a Type 348, if not what is its designation?
Cheers Bertram 94 Silver Star
Bertram
Re: Replacement ignition key
Postby DAVID THOMPSON » Wed Jun 24, 2015 8:05 pm
keys are zada
lots of bikes use it
and i can not get the search to work
and rotax is 504e on mz bikes
i have a 1995 saxon tour with that engine
always shut off your rotax with the compression release
then shut off the key saves the starter sprag clutch
Postby DAVID THOMPSON » Wed Jun 24, 2015 8:56 pm
had a hard time finding this the search on the mz riders is not finding older posts
there there search just does not see them
and the computer i have a bunch of this stuff stored on died the other day
but i can hear the hard drive still running so there is hope for data recovery
DAVE
FOUND THIS
will repost here
some buell blanks are same
if you know the cut number grahams in uk may be able to get you one
or blanks but get a pro locksmith to cut the new ones take key and blanks and the bike
i had a fit getting some new ones for the saxon tour cut guy had to take the lock apart
keykey keyskeys
BELOW FROM NOTES ON MY COMPUTER
Mz Key Blank Interchange
MuzTruckstuff on Thu Jan 17, 2008 5:57 pm
Did a little additional research on the key thing (hope this is the last post on it). Here's an interchange on the different bikes that use the same key as the Baghira/Mastiff. You can either source a key blank through a brand dealership or use the Ilco blank #X270-TCM1 via this list. This is just for information I got off the Ilco website. Paul
Ilco X270
Ilco EZ TMC1
Silca ZD24RDP
Aprilia
1996 - Present Motorcycles and Scooters.
BMW
2007 G650 XCountry, XChallenge, XMoto
1997 - 1999 F650 (Aprilia)
Buell
2000 - Present Blast
2000 - Present Firebolt
2003 - Present Lightning
2006 Ulysses
Cagiva
99-up
Derbi
1999 - Present. Most models.
Italjet
1996 – up
KTM
1996 – up
Malaguti
1994 – up
Moto Guzzi
1995 – up most models
MZ
1994 – up
Piaggio
Triumph
1997 – up Most models
Yamaha
1997 – 2001 Zuma scooter
Re: Keys
Post by amahoser » Mon Jun 16, 2008 9:22 pm
Just confirming David's post
I got a key cut from a local locksmith and the key blank he used was Silica ZD24RDP
Jose Soriano
buellbuell buellkeys
Return to 500 cc
