Am I rich?
Am I rich?
Postby RiverDrive » Thu Jun 09, 2005 7:49 am
My Sport Cup is doing a lot of "snap crackle & popping" when engine braking. Am I running rich? If so how do I adjust the mixture?
01 Sport Cup Gone Sport
RiverDrive
pop
Postby Nobog » Thu Jun 09, 2005 9:01 am
My Tour will backfire about once every 500 miles when off the gas and coasting, otherwise runs perfect. It rather startles me as it is so seldom. JK, reason? good question...
Nobog
Postby phlat65 » Thu Jun 09, 2005 9:22 am
sounds like the carb deff needs some jetting, or there maybe some debris in the idle circuit. did you put on a pipe with no jetting changes? it is best to get a jet kit than try to set up yourself. not very adjustable carb..
Postby RiverDrive » Thu Jun 09, 2005 10:41 am
Yes I did put an M4 can on the bike last fall with no jetting changes. It ran great all winter. Just recently the weather heated up above 90F and I thought maybe the change in air density had something to do with it. The idle speed also dropped and had to adjust it.
RiverDrive
Lean
Postby cdfisher » Thu Jun 09, 2005 1:34 pm
Sometimes backfiring can indicate a lean condition. Call Dan at the number below and he will discuss what you could do. Tell him you're from the MZRiders forum.
Curtis Fisher
President
MidAmerica PowerSports Plus
816.777.1785
http://www.mapsp.com
cdfisher
MZ Dealer
Postby RiverDrive » Fri Jun 10, 2005 8:12 am
Thanks Curtis
RiverDrive
Users browsing this forum: Bing [Bot] and 31 guests
