Mastiff hesitant runing
Postby ericetz301 » Mon Aug 10, 2015 2:59 am
hi folks collective wisdom please.
I have a 2001 Mastiff 42 K miles, that has started running oddly, not quite miss firing but running hesitantly, easy starting and smooth tick over, I've changed the plug NGK DPR 8 BE-9, but, still the same symptoms.
any suggestions on a cure would be appreciated.
cheers Eric.
ericetz301
Re: Mastiff hesitant runing
Postby den » Mon Aug 10, 2015 4:12 am
could be the symptoms of a weak spark.Have you had the tank of and checked the condition if the connectors and earths to the coil and the ht lead,unscrew your plug cap off and check that also.
den
Postby DAVID THOMPSON » Mon Aug 10, 2015 7:35 am
my traveller went flaky one day
the plus wire was loose on the coil at the wire spade
Postby ericetz301 » Tue Aug 11, 2015 4:15 am
thanks guys,
I will check out what has been suggested, and post the results.
cheers Eric.
ericetz301
Postby duncmac » Tue Aug 11, 2015 9:30 am
Check the choke plunger is not jamming.
Theres other posts on here with more detail, but basically
unscrew the choke cable end from the carb.
At the end of the cable is a spring and the plunger
Clean out the orifice
Clean the plunger
lube with a tiny smidgen of silicon grease
replace and check that the idle speed changes as you move the choke through its three positions (fully off, one click on?, fully on)
Other than that its fuel air and spark.
Any blows on the exhaust
any leaks in the airbox>carb>engine rubbers.
Is the air filter fully covering the air intake (check at the bottom with gloved fingers)
Any loose wiring?
MZ Baghira 2002 - Silver
CBR 600 FY 2002 - Tri colour
duncmac
Postby breakwellmz » Wed Aug 12, 2015 4:54 pm
Do the easy stuff first-drain the float bowl.
Postby DAVID THOMPSON » Wed Aug 12, 2015 5:38 pm
YES the float bowl is a problem on all my bikes and the truck
a lot of the time
and the big lawn mower till i started using the ethanol free gas
Postby duncmac » Thu Aug 13, 2015 1:57 am
breakwellmz wrote:Do the easy stuff first-drain the float bowl.
Quite right, the drain screws are made of cheese btw.
While your doing it you could connect a bit of clear hose up to the float bowl drain an check the fuel level in the bowl, by holding the end of the hose up.
Might indicate your floats set too high and running rich.
duncmac
Postby ericetz301 » Tue Sep 01, 2015 7:25 am
hi folks,
Many thanks for all the suggestions to cure the problem, I`ve now replaced the ignition coil C/W HT cable, treated the bike to a new Iridium plug, washed the air filter & re oiled it and finally cleaned and lubed the starter plunger assy.
The bike runs a treat now :D its`a shame we`re heading for the winter :|
cheers Eric.
ericetz301
Users browsing this forum: Bing [Bot] and 24 guests
